Decal will not stick...HELP!
Old Sep 7, 2001 | 01:20 PM
ED DINAPOLI's Avatar
ED DINAPOLI
Default Re: Decal will not stick...HELP! (JRChurch)
Rick,
You might try to clean it with lacquer thinner or grease and silicone remover. Is this a decal or a lable? If its a lable you can use some crazy glue on it. You might find that you have contaminated your lable or decal in the process and need to replace it.
Ed
Old Sep 7, 2001 | 03:29 PM
Stewart's74's Avatar
Stewart's74
Default Re: Decal will not stick...HELP! (ED DINAPOLI)
Sounds like the adhesive on the decal is now shot.
Here's what to do. Carefully remove decal. Use lacquer thinner to clean the part to remove any remaining grease or adhesive. Get a can of 3M spray adhesive ( Wal-Mart) Spray back of decal. Put it back on.
Old Sep 7, 2001 | 07:09 PM
Steve Grodin's Avatar
Steve Grodin
Try this link. http://forums.corvetteforum.com/zerothread?id=141861
To Decal will not stick...HELP!
