Flat tappet to solid roller
Old Aug 15, 2006 | 10:06 PM
Highhat's Avatar
Highhat
Default Flat tappet to solid roller
Has anyone gone from a flat tappet to similarly spec'd solid roller cam and measured the difference in performance? I'd like to know the real world difference. Thanks
Old Aug 15, 2006 | 11:31 PM
Little Mouse's Avatar
Little Mouse
Be carefull Ironcross will be on here warning you of the evils of
roller cams It would be hard to justify all the cost of a roller
cam over the cost of a solid flat tappit for the xtra HP.
Old Aug 15, 2006 | 11:39 PM
spookytooth's Avatar
spookytooth
What's wrong with a roller cam?
Old Aug 15, 2006 | 11:42 PM
Little Mouse
Nothing but the cost. A solid flat tappit is just chunk of metal if it gets lubricated
right its a simple device with no needle bearings to worry about, but it
can not make as much power.
Old Aug 15, 2006 | 11:49 PM
spookytooth
Oh, Is that all.
My motto... "the hardest, most expensive way"
Not on purpose, it just seems to end up that way
Old Aug 15, 2006 | 11:52 PM
GTENIT's Avatar
GTENIT
I Dont Know The Differance Same Spec To Spec Differance, But I Went From A Hyd Roller 230i 236e To A Solid Roller 240i 248e And A Big Differance. The Cost For A Roller In The Old Small Block Is Very High Compared To A Flat Tapet Cam The Cam Isnt That Much Higher But The Lifters Are In The 4 To 600 Range. If You Have A Newer Block The Lifters Are Not Near As Bad On The Wallet.
To Flat tappet to solid roller
