I'm purchasing a TKO-600 for my 69 SB Coup,e and the instruction say to loosen the exhaust manifold bolts. I assume this is to allow the engine to angle down to install the transmission. I have headers and I wondering if the bolts have to be removed completely or lossened enough create some movement. Any other hints about installing this would be welcome.
PS This whole job started out to install Vintage Air, but while the dash is apart I may as well strip the interior and insulate, put carpet, new seat covers, re-dye the panels etc. Oh and while the dash and console are off may as well swap the 4 speed for a TKO-600.
I had hooker sidepipes on mine, so I didn't have to loosen from engine. Just removed the pipes. After doing mine, if it had stock exhaust, I think it would help more if you dropped the exhaust pipes and even the intermediate pipe that goes through the x-member. Things are REALLY tight when trying to install the trans, so the more stuff that's out of the way, the better. gkull, nice looking Vette.
I have the same thing, Hooker sidepipes. So it sounds like I'll pull the pipes as well and that should allow the engine to drop down.
One question I keep debating is pulling the engine and installing on the ground or leaving the engine in and doing it the air. I do have a four post lift and high tranmission jack. After going through it would you still leave the engine or pull it?
If you have a lift and trans jack you should be good to go. All I had was jack stands and it was difficult. If I had it to do over again, I'd pull the motor and install as a unit. The attached thread has a few more observation. Good luck.
I did the auto to manual conversion. So I had quite a bit more to do.
I had no problem mounting the tranny to the motor and bell housing in the car.
I bought the blow proof bell housing with the 11 inch 22 pound billet steel 168 tooth 11 inch fly wheel. I mounted the bell housing and did the run out check. I had the Motown 427 small block at the time and it was near perfect alignment.
The problem was the McLeod steel bell housing was so exact in machining that i could not get the tranny into to bell housing. So I had to take it down and use fine sand paper to remove the paint on the inner bell housing to tranny surface.
Then my 427 small block blew up within a short period of time. So i had to pull the 427 ci and install my spare 383.
I could not get the 383 to mate to the installed TKO 600. Even with a motor leveling device on the engine hoist. We tried everything!
So we (fellow CF member) pulled the tranny and installed the motor. then installed the bell housing and last the tranny.
My advice is order Amsoil tranny fluid. It's cheaper and better than the GM syncromesh stuff that i bought. At my rip off local Chevy dealer it was $38 for three quarts with tax. It actually only requires @ 2.8 quarts to fill to the overflow mark.
If you have an auto and are swaping in a TKO, your cross member will come out. 4 Speed cars are welded in. W/O the xmember to get in the way, installation would be easy w/o pulling the engine.
My advice is order Amsoil tranny fluid. It's cheaper and better than the GM syncromesh stuff that i bought. At my rip off local Chevy dealer it was $38 for three quarts with tax. It actually only requires @ 2.8 quarts to fill to the overflow mark.[/QUOTE]
not taking anything away from gkull but Tremec recommends that you only use gm syncromesh we have had customers use other alternatives with poor results i.e. shifting problems. that's just my 2 cents
Like i said i did use the GM syncro oil with a metal conditioner additive. It really comes down to who do you believe.
sorry didn't see that in the description. Wasn't as transparent to me
just amsoil tranny fluid makes no metion of syncromesh or additive's
thank you for the correction
Just wanted to say it is nice having Gene here on the forum. My kit was shipped out on Friday so I should finally have it by the end of the week. I was using Gene as my go between Corvette Central and Keisler. Thanks Gene for looking after me.
I think that I would cut the crossmember out and make it removable.
Anyone ever document this process showing how to re-attach it?? Someone told me to get a cross member from an automatic that's a bolt on, but I can't believe it's as simple as cutting the old one out and just bolting the new one to the frame. Height differences, etc.
