Differential Fluid Replaced -- Problem???
Old Sep 8, 2001 | 01:13 PM
VolVette's Avatar
VolVette
Default Differential Fluid Replaced -- Problem???
I bought 2 Qts. of Mobil 1 75W-90 Synthetic Differential Fluid and the GM Positraction Additive this morning and drove to a small, local shop and had them replace my Differential fluids.
Now, my Vette's differential clunks as badly (maybe worse) as it did before I replaced the fluids. Does anyone have any idea why this could be? I need to adjust my timing/carburetor because my engine races (1300 RPM at idle) and I know contributes to the clunking.
Other factors that might help.
-ZZZ crate engine 20K miles
-Original Tranny, Differential
-Auto 3.08 gears
Thanks for all of your help.
Old Sep 8, 2001 | 02:10 PM
TedH's Avatar
TedH
Default Re: Differential Fluid Replaced -- Problem??? (VolVette)
Clearly the high idle is contributing to the clunk. If original driveline, it may be time to consider replacement of u-joints and rebuild of rear diff.
Old Sep 9, 2001 | 01:05 AM
LAvetteman's Avatar
LAvetteman
St. Jude Contributor
are you talkin bout when you shift in and out of gear?
[Modified by 71,454,4spd, 11:05 PM 9/8/2001]
Old Sep 9, 2001 | 01:09 AM
trw's Avatar
trw
AT 1300 rpm a lot of things will clunk.
Do a half dozen circle 8's in a parking lot and see if it helps.
Terry
To Differential Fluid Replaced -- Problem???
