Diffence between L48 & L82 ?
Old Aug 21, 2006 | 10:05 AM
duch54's Avatar
duch54
Default Diffence between L48 & L82 ?
Hi Guys,
Mechanically speaking except the L82 is more powerful than the L48 what exactly the differences are? (I mean what the parts are different?)
Old Aug 21, 2006 | 10:18 AM
24695bob's Avatar
24695bob
Not really sure .. BUT
The blocks AND the heads were the same..
Carb & Distributers differed...
Someboby should give Both of us the full story on what was different...
Bob G.
Old Aug 21, 2006 | 10:22 AM
Duke94's Avatar
Duke94
For starters:
Block: L-48 2 bolt mains, L-82 4 bolt.
Intake manifold: L-48 iron, L-82 Aluminum.
Crank: L-48 Nodular iron, L-82 Forged steel
Camshaft: L-48 .39inlet, .41 exhaust, L-82 .45 In .46 ex.
Valves springs are different
Valves are bigger in L-82
Pistons are different (cast vs impact extruded)
Rings are different.
Star79's Avatar
Star79
L-48
HP/TQ 195/285
comp ratio 8.2:1
2-bolt main
garbage cam
crappy heads
cast iron manifold
L-82
HP/TQ 225/270
comp ratio 8.9:1
4 bolt main
much better cam (still not as good as a modern aftermarket one though)
heads are a little better
aluminum manifold
better rods/pistons/crank (forged, I think)
The above are for the 79 version, other years may not be exactly the same, check out http://100megsfree4.com/corvette/ for stats on other years.
Old Aug 21, 2006 | 11:04 AM
duch54's Avatar
duch54
Originally Posted by Duke94
For starters:
Thank you Duke94
Old Aug 21, 2006 | 11:11 AM
duch54's Avatar
duch54
Originally Posted by Star79
L-48
HP/TQ 195/285
comp ratio 8.2:1
2-bolt main
garbage cam
crappy heads
cast iron manifold
L-82
HP/TQ 225/270
comp ratio 8.9:1
4 bolt main
aluminum manifold
Hi Star79,
Thank you for your infos, i see you are in Montreal so may be you speak french. I'm French and i just get a 80 i'm not totally familar yet with the mechanical English terms, so if you can write it in French it will be nice. Thanks
Old Aug 21, 2006 | 11:38 AM
Star79's Avatar
Star79
Originally Posted by duch54
Hi Star79,
Sorry, my French sucks. I'm really from Florida, just stuck here temporarily. :o
Peut-etre quell q'une d'autre peut tu aide avec la traduction
(see, that ^ sucks...)
Old Aug 21, 2006 | 11:58 AM
Michel B's Avatar
Michel B
From: Ville de la Baie Quebec. A winner is just a loser who tried again.
Hi Star79,
Salut !!,, ecoute,, si tu a un probleme avec les traductions sa me ferais un plaisir de t'aider.
Old Aug 21, 2006 | 12:00 PM
duch54's Avatar
duch54
Thank you anyway, yor french it's not so bad.
Merci
Old Aug 21, 2006 | 12:11 PM
duch54's Avatar
duch54
Salut Michel B,
Merci d'avance pour ton aide, si tu peux me traduire:
Bolt mains ( Block: L-48 2 bolt mains, L-82 4 bolt)
Intake manifold
Crank
Ca serait kool
Old Aug 21, 2006 | 12:26 PM
Michel B's Avatar
Michel B
Oui, mais excuse moi pour mon ortograph,, je suis bien Quebecois mais j'ai fait mes etudes en englais,,lolll
Bon, ils parle des ecrous sur le cap principale du crank, le L-48 en avait 2 est le l-88 en a 4. en fait ca ne veut rien dire, a moins que tu veut faire du drag le 2 bolt est tres bon pour jusqu'A 500hp. les moteur a 4 bolts etais populair dans les camions,, un peut plus robuste pour le travail. Gene toi pas si tu d'autre question,, tu peut m'Envoyer des couriel est je t'Aide autent que possible... bon je doit retourner au travail ,,lolll
Oups,, je viens de remarquer que tu avait d'autre question,, je ne connait pas le vraie terme francais pour le intake,, au Quebec on utilise le terme intake,, mais bon je m'explique; ces la piece qui est just en dessu du carburateur, pour l'entré d'air. Est le Crank ces le vrillebrequin du moteur,,, voila...
Old Aug 21, 2006 | 02:54 PM
justanotherdoe's Avatar
justanotherdoe
Cette leçon française de C3 est trop drôle
Old Aug 21, 2006 | 04:34 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
L82s also got a bigger (thicker) radiator.
To Diffence between L48 & L82 ?
