another jeep box question
Great to know. Who makes a cheap adapter plate to use a T5 on a GM motor? And what driveshaft mods have to be made?
Bernie
Bernie
I'm not THAT interested. I drive an auto not and don't want the hassle of changing it over to manual. But, if I ever get myself into a manual Vette down the line, I will install a T5 for sure. The hole location drawing would be helpful to others ont he forum doint the swap...I know of one who is for sure. It would be a great help if you could dig that up and post it. Thanks.
Also, did anyone who did this have to modify their shifter plate at all?
Remember even 700 foot pounds wouldn't break that tranny. Power shifting with a much lesser motor would.
If you check out just a plain TKO say from Hannlon you might be supprised.
Drive shaft mods?? Slight shortening but any drive line shop can do it cheap. The mustang and the vet take the same universal. That is no problem.
This sure went away from the Jeep box post it started out as
All the parts for a manual steer change are availible except the center/drag link. I read that many owners have just converted using the PS center link without a dampner - yes run manual steer without dampner. Most will want to move the tie-rod to steering knuckle connection to the rear for the slow steer ratio - same as the manual steer used (except L88 vettes). And if you wanted to install a dampner to a PS center link u could measure it out and have a small bracket welded onto the center link for the dampner connection - all other parts are still sold new. This would alow u to use PS centerlink and pitman arm.
To convert to man steer:
1 - remove PS pmp & pulleys, belts
2 - remove slave cyl
3 - remove control vlv & hoses
4 - set tie-rod to rear hole on knuckle
5 - set steering toe
To add dampner:
1 - buy dampner and frame end bracket ($150)
2 - size up dampner to center link location - ensure u have enough travel for dampner in both directions
3 - fab and weld dampner bracket onto center link - dampner bolts on with 2 bolts to bracket
Your there, now manual steer.
Just my 2 pennys folks. cardo0
I wouldn't say I really siffer from either of those. Are they a common problem or something EVERY Vette owner experiences but doesn't notice?
Weight. Pulled 'bout 10lbs off the front end.
1 fewer belt.
Several less parts to break - greater reliablity.
Save a few hp too - less parisitic loss.
Ok NASCAR even uses PS just to make left turns but they have a full pit crew and much larger buget than me.
cardo0
After replacing all my PS parts 1 at a time the seals dried up from lack of use (i think) while car was down and leaked so bad i had to refill pmp nearly daily.
1 fewer belt.
cardo0
Doesn't the lack of power assist make the turning more difficult? I've driven one of my first '77 Vettes with no power steering belt installed and it was a witch to steer. Is there something about it I'm missing?
No, just removing the belt is no way to compare PS sys to Man steering.
cardo0
cardo0
Say I want to keep the power steering system intact, and install the Jeep kit...how can the remaining system be altered to enhance the steering...if there is a way.
Great to know, thanks. How long did it take you to find yours?
As far as just going with manual steering, I used to have a '65 Mustang coupe with manual steering. Even on those skinny little '60s tires, parking that thing was a good arm workout.
