clean fiberoptic wires??
Old Aug 24, 2006 | 03:49 PM
larry hinterman's Avatar
larry hinterman
Default clean fiberoptic wires??
How do we clean the ends of the fiberoptic wires to make more light go through?
Old Aug 24, 2006 | 03:54 PM
Durango_Boy's Avatar
Durango_Boy
Hydro Peroxide and a can of compressed air to speed dry it.
What do you use the fiber wire for?
Old Aug 24, 2006 | 04:12 PM
7T1vette's Avatar
7T1vette
'68 thru '72 Corvettes had fiberoptic lines run from each external light bulb to the cockpit shifter plate...to show which lights were working properly. [No light....bad bulb.]
Are the plastic pieces (where the fibreoptic lines are inserted) in good shape? I have one with part of the receptacle cracked off and it has low light as well. I've not had any problem with the others.
Old Aug 24, 2006 | 04:14 PM
Durango_Boy
That's cool, but seems like it'd be a hassle to work on.
Old Aug 24, 2006 | 04:29 PM
Carl Granquist's Avatar
Carl Granquist
Default lights
The "coolness" far outweighs any maintenance hassles.
Old Aug 24, 2006 | 04:30 PM
Durango_Boy
Ever wonder why they stopped doing it?
Can it be adapted to a '77? That'd be a fun mod.
Old Aug 24, 2006 | 04:45 PM
Carl Granquist
I've heard Chevy stopped it in '72 and instead made the theft-deterrant alarm system standard.
I think some of the vendors have the fiber optic harness available, at a price, but I'm not sure how you would incorporate it into your console.
If you haven't seen them before, try a night cruise in a '68-'71.
Old Aug 24, 2006 | 04:48 PM
Twin_Turbo's Avatar
Twin_Turbo
can you get the crimp on ends somewhere? I'm working on a 69 where I got all but one of the fiber opics to work because someone cut the end off, the rest wasn't working due to overspray and dirt
Old Aug 24, 2006 | 04:55 PM
NHvette's Avatar
NHvette
I'm guessing you're referring to the brass do-dads shown here:
http://www.zip-products.com/Zip/dept...7E198E222A1CAE
Might also be able to salvage parts from 80's-90's Buicks and Cadillacs.
These might be the larger diameter fibers.
here's a pic of the optics location in my 89 Buick Park Ave ... block of indicators in the center of upper dash.
Also, a block is at the top of the rear window - views rear light operation in rear view mirror.
http://NHvette.com/ftp/in/Buick_interior.jpg
Floor mats optional.
Old Aug 24, 2006 | 05:00 PM
Twin_Turbo's Avatar
Twin_Turbo
that's the stuff
Old Aug 24, 2006 | 05:08 PM
Durango_Boy
Yeah, but I'm sure I could fab up something if I ever get real serious on the idea.
Old Aug 24, 2006 | 06:15 PM
noonie's Avatar
noonie
Optic cable is dirt cheap and you can have a lot of fun doing all sorts of stuff with it.
Here is a link for the cable.
http://www.fiberopticproducts.com/Endglow.htm
Almost any small lenses will work or you can get colored cable. Do google searches for limos and you will find some how to's
Old Aug 24, 2006 | 06:19 PM
Durango_Boy
Very cool man. Maybe when everything's done I'll put together a fun fiber optic projet.
Old Aug 25, 2006 | 04:21 PM
NHvette's Avatar
NHvette
There was another supplier that carried cable by the foot and all the parts, too.
Anyone have a link to this (can't find with Google).
Old Aug 25, 2006 | 04:34 PM
Durango_Boy
Can someone snap a pic of the panel inside that shows the lights on/off status? Maybe botha day and night photo? Thanks.
To clean fiberoptic wires??
