68 Radiator core support question....
Old Aug 28, 2006 | 12:26 AM
sperkins's Avatar
sperkins
Default 68 Radiator core support question....
So what options are available on the '68 to get a larger aluminum radiator without swapping out the core support?
I plan on installing a built 383 in the next couple of months.
Old Aug 28, 2006 | 12:55 AM
wombvette's Avatar
wombvette
You can use the larger BB with AC type support that had the brass radiator and the fiberglass shroud, but that would require a support swap or at least a modification.
Old Aug 28, 2006 | 09:06 AM
sperkins's Avatar
sperkins
ttt
Old Aug 28, 2006 | 12:09 PM
waterplay's Avatar
waterplay
I am also interested in this answer. I got the Dewitts with the fan and controller. My car runs about 220 all the time fast, slow or still. I was told short of replacing the support I am stuck with what I have.
Old Aug 28, 2006 | 12:17 PM
sperkins's Avatar
sperkins
I'm confused. Have you already installed the Dewitts?
Old Aug 28, 2006 | 01:35 PM
682XLR8's Avatar
682XLR8
You shouldn't have to change the rad support. I'm using a DeWitts Direct-Fit made for the small-block, and stock fan for my 383. Keeps the temp at 180, even less on cooler days
Old Aug 28, 2006 | 01:49 PM
carriljc's Avatar
carriljc
Default I put in a 28" by 19" in my 68.
I got it from Summit. I removed the lower round-cushion brackets and used generic brackets to mount it. It fit with ~ 3/4" on each side.
Old Aug 28, 2006 | 02:02 PM
sperkins's Avatar
sperkins
Thanks for the info from everyone so far.
Is this the one you purchased?
http://store.summitracing.com/partde...5&autoview=sku
Old Aug 28, 2006 | 02:45 PM
carriljc's Avatar
carriljc
Default Nope, here's the one I bought....
I wouldn't go any bigger than 28 by 19.....
And here's the brackets I bought...had to modify them, but for what they cost it's simpler than going to find metal.
http://store.summitracing.com/egnsea...DS=1&N=700+115
Old Aug 28, 2006 | 04:00 PM
waterplay's Avatar
waterplay
Yes, the Dewitts is already installed. I have a new high flow water pump new T-stat and fresh motor. I can only imagine what the temp would be without the Dewitts. I have checked the temp difference inlet to outlet with a temp gun and it is lowering the temp by about 20deg. The radiator support opening on a 68 small block is just to small to run a decent size rad. Thought about cutting the opening larger and making another larger radiator fit But I hate to just throw away a brand new good Dewitt rad.
Old Aug 28, 2006 | 04:32 PM
carriljc's Avatar
carriljc
Default I thought about cutting also...
but I decided to just install the radiator first. I have A/C and I have not overheated. I live on the coast so it isn't exactly hot, but even on warm days it runs just fine.
One of these days I'll take it to the desert. The 28 X 19 radiator is quite a bit larger than the little original aluminum radiator I removed. I was surprised how small the original was when I got it out.
Old Aug 28, 2006 | 04:38 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
The 68 was a little unique but not impossible. Assuming it was a small block core support (you didn't say) then there were two different models. First you had the manual/no air radiator which was aluminum (pin mount) and used a separate surge tank. GM 3155316 our #941 or A63M.
Then if the car got AC or Auto, GM changed it to a copper unit without surge tank. The radiator was the same copper/brass radiator they used for the 68 bb and it mounted on the U saddles. We would convert this to aluminum with a model A66 which uses a 22.5" core.
I have too many options to list here as far as up grades go, so if you are really interested in upgrading I suggest you call me and we'll run through all of them. 810-220-0181
Old Aug 28, 2006 | 07:37 PM
waterplay's Avatar
waterplay
Tom,
Email sent. Too late for phone #
Old Aug 28, 2006 | 08:42 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Tom,
I didn't get one. Use tom@dewitts.com
To 68 Radiator core support question....
