Frame restoration question
Old Sep 4, 2006 | 07:55 PM
MonzaRedConvert's Avatar
MonzaRedConvert
Default Frame restoration question
Ok, so I took the plunge. After seeing all the beautiful frame restorations on this site I decided to take my body off and give it a shot. D*** you all! J/K, actually it went pretty smoothly after I unbolted the seat belt mount.
Anyway my plan is to clean up all the looses scale and paint it with POR15. My question is this: what can I do about the inside of the frame. As I understand it these things can rust from the inside out. Short of drilling a lot of holes is there some way to rust proof it?
Thanks,
Doug
Old Sep 4, 2006 | 08:18 PM
72LS1Vette's Avatar
72LS1Vette
There are enough access holes in the frame to reach everywhere so you shouldn't have to drill any holes. Eastwood sells a rustproofing kit that has wands of different lengths for reaching into the frame. They also have a waxy coating that is supposed to stick to the inner frame and prevent moisture from getting to the metal. I also considered using chainsaw oil - it is a paraffin-based oil that will stick to the surface pretty well also.
Rick B.
Old Sep 4, 2006 | 08:54 PM
Bob Onit's Avatar
Bob Onit
I used to spray waste oil in the holes with an undercoating gun.
It saved the frame on a Toyota pickup I had for many many years... Box frame BS.
It's messy but it does work well.
Of course you would want to do this after you paint the frame
Old Sep 4, 2006 | 08:55 PM
CF6873's Avatar
CF6873
I used a long wand and applied Rusfre inner panel coating. It is the waxy stuff that stays somewhat sticky. I put enough in until it started to drip out of the holes.
Old Sep 4, 2006 | 09:04 PM
71-Stingray's Avatar
71-Stingray
Originally Posted by 72LS1Vette
... Eastwood sells a rustproofing kit that has wands of different lengths for reaching into the frame. They also have a waxy coating that is supposed to stick to the inner frame and prevent moisture from getting to the metal.
This is the path that I'm taking as well.
Old Sep 4, 2006 | 09:15 PM
Vettkeeper's Avatar
Vettkeeper
After spraying the POR-15 on the frame, whatever was left in the spray gun jar I set the paint gun for a narrow width and sprayed it into ever hole in the frame I could find.
Old Sep 4, 2006 | 10:02 PM
Bob Onit's Avatar
Bob Onit
The reason I used waste oil was because certain substances will actually trap moisture and accelerate rust
I am not familiar with POR-15 but I know that the basic undercoating spray you buy can hold in moisture.
Looks like theres alot of options
Old Sep 5, 2006 | 11:36 AM
68 NJConv 454's Avatar
68 NJConv 454
Where do you find "waste oil" or this waxy stuff?
Old Sep 5, 2006 | 01:22 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
you have "waste oil" after you change the oil in your car.
That's why the front half of a frame is not usually rusted, it's from all of the oil that
gets on the frame from oil changes, oil leaks, etc.. over the years.
Old Sep 5, 2006 | 02:49 PM
Scott Marzahl's Avatar
Scott Marzahl
The other products you can use are the Rust Converters, SEM makes one that does not require coating afterwards, it is called Rust-Seal.
You can use a wand and spray it in the frame holes. Availble at all autobdy supply stores.
Old Sep 5, 2006 | 04:03 PM
MonzaRedConvert
Thanks for all the replies. I'm not sure which I'm going to go yet. I've got plenty of work to do before I get to that point!
Old Sep 7, 2006 | 11:58 PM
68 NJConv 454
What if you sprayed that airconditioning duct sealer from home depot into the frame? Comes in a spray can with a small straw, comes out like an oozing liquid but quickly expands to almost 7 times its size. Stick stuff and becomes a great sealant. Would that work if I sprayed that in my frame? might just take space and not really seal the inside metal from moisture...just a thought.
Still searching for something that I can spray in the frame to seal it from further rust. I have no way of getting the surface rust in there out. Ideas? products? what about eastwoods rubberized coating?
Old Sep 8, 2006 | 12:54 AM
hwcoop's Avatar
hwcoop
I have found rustcheck to work great!, it is oil based so it soaks through the rust and stops it, comes in spray cans or you can use a shutz gun
http://www.rustcheck.com/products.as...6&ProductID=35
Old Sep 8, 2006 | 11:09 AM
68 NJConv 454
Awsome, just sent the company an e-mail to see which product would best serve my needs. I'll post what I find out.
Old Sep 8, 2006 | 02:41 PM
68 NJConv 454
Spoke to someone at RustCheck and they recommended RustCheck Coat and Protect for inside the frame to be applied via a Shutz gun.
The Coat and Protect is a heavy gel that will work its way into the surface rust and any other debri within the frame and preserve the current state. It won't allow any more rusting to occur. Obviously they do a lot of this in Canada and apparently RustCheck is pretty popular. They just opened shops in the Pensylvania area that applies RustCheck to customer cars but doesn't retail the products.
Anyway, they said you don't want to seal the inside of the frame with anything with a hardner b/c as you drive the frame twists and would crack the hardner allowing moisture and rust to grow beneath the hardner. Makes sense.
So I have to find a way to order this stuff to the states and give it a shot. He mentioned I would only have to do this once every 2 or 3 yrs.
If you want more details e-mail me at doogie1101@hotmail.com and I'll share the info I have gained as well as what I will find out.
Good luck.
Old Sep 8, 2006 | 03:12 PM
noonie's Avatar
noonie
Whenever I have done a frame inside, I shoot it with Ospho, which stops the rust etc. Use a weedsprayer very liberally. Then shot the inside with the good Rustoleum thinned way down using a body shutz gun.
Then spray the outside of frame that has been sandblasted and prepped with ospho with the rustoleum in numerous coats to get complete coverage and a smooth finish.
Looks great and can be worked on later without fear of destroying a fancy expensive coating such as powder or epoxy. Also no worry of trapping moisture. Works for me.
Old Sep 8, 2006 | 09:27 PM
hwcoop's Avatar
hwcoop
In some parts of the northeast during the winter months they use to spread so much salt on the road its like driving down a gravel road
My new 77 El Camino had rust holes in 3-4 years when rustcheck came out I use to spray it inside the door shells and rear quarter panels...stopped the rust dead. I'm not selling the stuff...just a great product
To Frame restoration question
