The forum has the best advice. I am looking for a rebuilt 400 tranny and need opinions on B&M, TCI, Hughes or other vendors. I am putting a 350 in with 360 HP, 400 torque cam is 224/230 at 450/460 lift. My rear end is in the shop right now and I will have 3.55 gears. Will a 2000-2200 stall converter work. I know the OD transmissions are the way to go but this frame off complete resto is sucking me dry.
With that mild cam & relatively low rear gear ... I don't think you need a hi-stall convertor ... think stock TH400 & stock convertor OK ... just my .02.
If you have the old tranny, you can get a reputable rebuilder to install quality parts and you'll be fine. Get rid of all of the plastic seals and shims possible. You'll end up with a non-metallic selective shim on the front minimum. Consider a transgo shift kit; it will make a difference. The other vendors make the shift kits too, but get a transgo.
if you stay with around 2000 stall, just use the factory TC and save the $$$. otherwise look for TC with about the same stall (good converter company will ask you for all your car info), greater torque multiplier, and efficiency. these things cost; good companies can provide proof of performance; if they can't prove it's better than factory, don't buy it (or hype).
If you are concerned about off the line performance, DON'T put a stock converter in it. Up to 2500 stall speed is barely noticeable in normal driving but makes a big difference in drag strip performance. I just put a Transmission Specialties converter in my car. You can find good deals on them, new, on Ebay.
Which one do you have, any problems with Transmission Specialties
Stock SB tq converter is 1500-1600. I would DEFINETLY install a looser converter. I would go with the Hughes 2500 stall. Its only about $150-175 and its much better quality the B&M and TCI junk.
You will barely notice driving a 2500 with a 3.55 gear but it makes a significant difference when you nail it from a dig.
Stock converters suck.
I knew the minute the words torque converter were mentioned it
was just be a matter of time before you showed up to warn of the
evils of stock converters.
I have a 400 trans with a 2800 stall and 3.55 gears also awell used 300 hp base motor. I did the stall and the 3.55,s at the same time, what a difference,like night and day ,it smokes,em with my tiered old motor. but it needs that bill mitchell 427 small block
St. Jude Donor '03-'05-'06-'07-'09
So B&M and TCI are Junk???
What about Transmission Specialties, I see some good deals on Ebay?
Going to put together a 383 with TH400 and a 308 rear gear in my 72...I will need higher stall speed....thinking about a 2500 stall speed.
I agree with those recommending a 2500 RPM stall. It'll liven up your car noticably. Anything much higher than that will be slipping at highway speeds & create alot of heat, which is the enemy of your trans. I also recommend a trans cooler to keep temps down for longer life.
S489 recommends a Tran-Go shift kit, which is what both of my local trans shops recommend & which I have in my TH-400. Neither of them will use anything made by B&M- I don't say that to bash folks who are using their parts, just passing it along for what it's worth. Good luck.
What about a TC built by Coan? I've heard alot of good things about them.
The stock vette converter was 2100 RPM it has been posted here before and is in some of the GM paperwork I have somewhere.
I just rebuild my complete 72. I'm running a mild cam,TH400, B&M 2000 stall, and 308's. It's just what I wanted from this car- a cruiser to drive on the weekend to shows. I could care less if someone has a faster car next to me- go for it.
I used the B&M master kit to rebuild and mod the tranny. The clutches were the same as any and the mods were also the same as the other kits and "tricks" used by tranny shops. My buddy faxed me a report on what the hot rod shop did to his TH400 and they were the same mods. So those kits are fine, you just have to decide what you want out of it and build it that way. I did swithch to a older drum and 32 element sprag for added strenght but it wasn't needed for this application. A stock TH400 from the late 60's to early 70's will be all you need.
With the street/ strip mods the only thing I notice is a slight 1-2 "thunk" at just above idle shifting, this is due to hihger pressures with the mods. During part and full throttle it ****s firmer then stock but not neck snapping fast.
I was always told to keep the stall speed under the cruising RPM to keep it from overheating. I used FORD old type ATF too.
Like others have suggested I would rebuild what I have. A good tranny shop can rebuild and install a shift kit at the same time, give you a warranty and you will know what you have and it is alot cheaper then a specialty company.
I would prefer the 350 to the 400. The 400 is heavier, larger, heavy duty so it eats about 35 more horse then the smaller 350.
A 350 can also be made to shift better then the 400 with a shift kit.
The 400 is only better for the really high horsepower bigblocks.
If you have a 350 save the money and get it rebuilt and gain that extra 35 horse. You will feel the difference
Previous owner must have modified this TH400, I have the have the same firm low speed shift from 1-2. From 2-3 is smoother, downshifts are good and passing is quick and firm
I have heard anywhere from 1400 - to now 2100 on the stock stall speed. Mine could have been chaged somewhere along the line.
Feels really low.
Anyway I can't find anything in the assembly manual or the GM sevice manuals.....
thanks Mark
thanks Norval
I really dont have any big issues on the transmission, except for a persistant leak, shifts good, feels strong. Just wondering if I should take it out, when the motor is out, to clean it the area around it??? Or go through it while it's out and change the convertor to a little higher stall speed.....decisions decisions
Mark
