QUESTION on block,heads,intake
Old Sep 11, 2006 | 09:40 PM
vettesbydesign's Avatar
vettesbydesign
Default QUESTION on block,heads,intake
i bought a 74 L84 burn car last year,and jerked engine,but not correct for the car.....would like someone/anyone help me run these numbers,PLEASE!!!!!!the block is #3970010,date I/6/2,and v1C(backwards C)23TJA....the heads are #3988991/GM62/J/19/2(left),and same for right,but dated I/27/2.......then the intake is aluminum...#14057053,GMcfm 16,and i haven't found a date yet anywhere.any help would be appreciated.....thanks
Old Sep 12, 2006 | 08:11 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
TJA indicates a 73-74 350CID truck block, but the 0010 block was also used in Corvettes. I62 is the casting date, probably September 6, 1972.
Heads are not Corvette and have casting dates of October 19, 1972 (J192) and September 27, 1972 (I272).
Unless I miss my guess, the V1C23TJA is the assembly date for the engine. It's probably V1023TJA. What appears to be a backwards C is likely to be an incompletely stamped zero. V is the pant code for the Flint, Michigan engine assembly plant. 1023 would be the calendar date the engine was assembled, in this case October 23rd. TJA is the engine code suffix which identifies it as a truck block.
Old Sep 12, 2006 | 09:20 AM
vettesbydesign
easy mike......was hoping that you would step upto the occasion,but don't stop there! so.......what's the intake from????factory aluminum...thanks.....
Old Sep 12, 2006 | 09:35 AM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Intake Manifold Info.
1986 Chevrolet
H.P. Disp. C.R. Ind.
155 305 9.90 1-4 Roch
165 305 11.05 1-4 Roch
190 305 11.10 1-4 Roch
Source (http://www.nhra.com/tech_specs/engin...ts/CHEV-86.rtf)
Regards,
Bob K.
Old Sep 12, 2006 | 10:15 PM
vettesbydesign
thanks for the info. guys....i have a buddy going crazy over a factory alum.intake.....guess,he can get it now!
To QUESTION on block,heads,intake
