well today i was picking up my car from the mechanics and he said he test drove the car and everything was ok. WELL, i got about 2 miles down the road with my friend in front of me and the car starts to sputter then ultimately dies...yea i know, wtf. I went bak and got the mechanic and had him come look at the car as it would not stay alive for moe than 5 seconds. Found out that the carbs floats were bad and the carb was leaking gas down in the motor. So i had to go get a new carb. I just want my car back!
How about a little information... engine, carb ect:
what do u mean? Like how the engine is doing at the moment or the engine specs? The carb was...dammit i need a jegs magazine. I think it was a holley 4150 or somethin. It was a hand-me-down from my uncle, lol.
dude, you got hosed, did you at least get a reach around? Even concidering the float was bad, thats a $12 part. Think about it, do you really expect that you have to trash a $400 carb for an internal part?
In here we need basic info on what ya have, that way we can help, thats wy we are here.
Did you keep the old carb? If not, what did you get for a core charge?
well i guess i forgot to say but i kinda needed a new carb too because this one was running too lean for my engine(not enough CFM). And me gettin hosed? I doubt it since the carb was free in the first place...
What I mean is Engine? L-48 L-82
Stock? any engine mods ... Intake manifold/Ignition timing ect:
Hard to diagnose a problem without knowing the specifics of the engine
Unless it was an old 2 barrel carb I doubt it was too lean
Stock? amy engine mods ... Intake manifold/Ignition ect:
oooooooooo ok. Gotcha. Here we go...it an L48 with edelbrock RPM heads 64cc, intake manifold, headers, roller rockers, roller lifters, stage 2 clutch, 3.08 rear end(i know.....), and internals are here:http://www.speedomotive.com/ps-46-8-...-race-kit.aspx
2 bolt. Havent u ever seen a 2 bolt stroked?, lol. They actually hold up pretty good. Its not like im gonna be spinnin 6500 rpm's all day or anything either. More like an every now-n-then kinda thing .
I bet you that carburetor is totally rebuildable. Probably just needs a good freshening up. One thing about a Holley, they will ALWAYS end up leaking at some point. That's just the flaw in their design.
Unless I mis understand the problem if you are getting gas back into the carb, the floates may be out of adj. If the floats are to high it will cause the extra gas to flow into the main throttle body. Once this happens the car will not stay running because it is drowning in gas.
Let's see.... I took my "working" car to the mechanic; I got it back and now I need a $400 carb. HMMMMM.
You're getting ripped off. Have the car trailered to a reputable mechanic, get your carb back, and tell them there is no way in heck that you're paying for a new one.
i myself think the carb was too lean because it was just a 650. Most strokers usually need a 750 or higher. Yes the carb was working when the mechanic test drove it and a day later when i was driving it home. Its just more like a freak accident kinda thing. Idk y u guys r hating on the mechanic when he did nothing wrong. I would also say that the carb is old but then some of u guys would come up and say "hey i got this so-n-so carb for so long and its still working yadayadayada. It was a hand-me-down btw. But the carb was just scarin the $hit outta me becaue even when the motor was shut off fuel was still flowing into the butterflies. Heres the carb:http://www.jegs.com/webapp/wcs/store...tegoryId=10271
Its just a replacement
for Quadra-Jets.
The size of the carburetor has nothing to do with it running lean or not. CFM is simply the amount of air the carburetor will pass through the bores. Jets, metering rods and air bleeds are what set the fuel air ratio not carburetor size.
