Reduction Pulley
Old Sep 16, 2006 | 01:31 AM
JonnHeather's Avatar
JonnHeather
Default Reduction Pulley
If I put a 25% crank reduction pulley on my 383 what is that going to do to the cooling/charging systems? Logically a reduction pulley on the crank shaft will cause the w/p and the alterantor to spin slower, but will this be enough to cause cooling and charging issues?
Old Sep 16, 2006 | 08:47 AM
flynhi's Avatar
flynhi
I tried this on my 350 and had charging problems and went back to the full sized pulley on the alt. No problem with cooling but I had a new water pump and radiator.
I don't think the slight increase in power will be noticeable on the street at lower RPM. Since you are running a 383 which are typically torque motors operated below 5,000 RPM, high RPMs where
the decreased drag resulting in more power does not really come into play.
Old Sep 16, 2006 | 09:09 AM
SIXFOOTER's Avatar
SIXFOOTER
at Idle you may very well run into a low voltage problem, it may or may not be a serious probem, it just means that at low engine speeds the cars electrics will be battery powered. IMHO those reduction kits harvest very little in the way of HP, certainly not enough to justify the co$t and then ya have to figure in the hassle factor..
Old Sep 16, 2006 | 09:33 AM
Gordonm's Avatar
Gordonm
For a street car don't do it. It is not worth the 1 or 2 hp it will gain you on the street. If your race motor is turning 5000+ rpm all the time it might be OK. Most of the time a street motor is at or below 2500rpm. Not needed.
Old Sep 16, 2006 | 12:47 PM
JonnHeather
Thank you everyone, think I will pass on this purchase. Time to find something else to spend money on. I doubt it will be hard!!!!!!
To Reduction Pulley
