Removing Chrome
Old Sep 24, 2006 | 11:56 AM
11Jake's Avatar
11Jake
Default Removing Chrome
I am polishing some aluminum parts on my Vett (door sills, rocker panels and back window trim) and when I stated to fine sand the rocker panels before polishing, the passanger side one is chrome plated but the driverside was etched aluminum. I stated to sand the chrome off the part but it is eating up the sand paper and taking forever. Is there an easy way to remove chrome?
Old Sep 24, 2006 | 12:19 PM
Durango_Boy's Avatar
Durango_Boy
There are some chemical dips available, but in all, it's VERY hard to manually remove good chrome, and the surface under it will suffer as a result. It's a plating, checmically bonded to the surface under it. Generally removing it takes some of that under-surface away in ****** or pits. You'd almost have an easier time buying a new panel that's polished, or another chrome one.
Old Sep 24, 2006 | 04:04 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Or take it to a plating shop and have it de-plated. They just reverse the electrical charge.
If you're brave, muriatic acid will eat chrome - but I imagine it would do nasty things to aluminum, too.
Old Sep 25, 2006 | 07:45 PM
Durango_Boy
I found a grinding wheel of a flap wheel will remove chrome too, but the surface is scarred pretty bad. I still think it's better to just get a parts to match either side or the other and not modify one to match the other.
Old Sep 25, 2006 | 10:58 PM
68/70Vette's Avatar
68/70Vette
As far as I know, the only practical way to remove chrome is to take it to a chrome plating shop and have then de-plate it. Actually when you take a corroded chrome piece to them for re-plating, they have to de-plate the piece before they can start to work with it.
Old Sep 25, 2006 | 11:03 PM
Durango_Boy
I was thinking of that for my sidepipes and headers. I'm guessing it's just as much to have them un-plated as it is to get it chrome plated.
Old Sep 28, 2006 | 11:22 AM
11Jake's Avatar
11Jake
Well I have most of the chrome off. It has been a huge pain in the A##. I stated with 80 grit sand paper on a sander to scratch up the chrome really good but not to much to get to the aluminum. Then I used 150 grit paper to get the chrome off. After I get the chrome off I used 250 paper and then 400 paper to get a really smooth surface. I did the other rocker panel (the one that did not have chrome on it) with the 250 then the 400 paper and polished it. It looks amazing.
Old Sep 28, 2006 | 12:16 PM
Durango_Boy
Good...I'm glad that went well for you. Can you take and post a pic of what it looks like now?
To Removing Chrome
