Fuel pump plate bolt
Old Sep 24, 2006 | 06:18 PM
Silver00V6Camaro's Avatar
Silver00V6Camaro
Default Fuel pump plate bolt
I had a fuel pump plate bolt brake off at the head. how can i get it out of the block.
Old Sep 24, 2006 | 06:35 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Yea, for some reason those 1/4-20 cap screws like to bust off at the head. Been there. Then broke an easy out tool off in the bolt.:o Man it took forever to get the easy-out out. Had to use a Hobo Freight 90* drill attachment and the drill bit just bored along side the easy-out into the bolt - well some of the threaded casting mount too.
Welding onto the bolt is not an option. And the tiny drill bit needed for that small a bolt likes to snap at anytime.
Do it again i would try to get a hi-speed tool (flex shaft) with a ball mill (hopefully carbide) -Dremel sells'm and grind it though the middle the best i could. Hog it out so the larger easy outs can get in there. Its a through hole BTW and maybe able to turn it out the back.
Good luck.
cardo0
Old Sep 24, 2006 | 09:34 PM
Silver00V6Camaro
thanks for the reply I called my buddy up and he had the special bits and got it out with no problem.
To Fuel pump plate bolt
