rear brake line help
Old Sep 26, 2006 | 02:27 PM
spille85's Avatar
spille85
Default rear brake line help
Hello Everyone, I recently replace all of my brake pads and the two rear brake rotors including the drivers rear brake line that goes to the caliper. Well after my test drive, i could smell my brakes burning, so after a closer inspection I narrowed it down to the drivers rear (the one I replace the line on). I took the brake apart and noticed that the new rotor has grooves in it caused by the brake pad. I examined the pads closely and they seem to be extremely clean. Anyways, I was wondering...once I put everything back together do I have to bleed the entire brake system or just the drivers rear brake? Please help..lost in Eagle Pass.
Old Sep 26, 2006 | 02:59 PM
SIXFOOTER's Avatar
SIXFOOTER
Well, yes you need to bleed them again to make sure you have all the air out, especially on the LR. Did you figure out wht that caliper was dragging?
