Vacuum reservoir/Bumper support removal questions
Originally Posted by turtlevette
That's not very strong, but better than nothing.
Originally Posted by strokervette
With the custom rad support mounts I made I am still able to push on the nose and compress the suspension. Even though this is not a desirable thing to do, I wanted to make sure if I hit any bumps that the frontend doesn't collapse. It's sturdier than you think. The frontend is a lot lighter without all that metal in there. For the back I just removed the entire bumper altogether and I'm getting a fiberglass bumper cover so that it stays solid back there. The rear bumber weighed liked 60 lbs as well. Yeah, I know, if I get hit it will be disastrous but I will take my chances. It's not going to be a daily driver.
I know the rear wasn't as heavy as the front but it's up there. I weighed myself, then held the part and the diff. is the weight of the part. Yeah, there is no room for error with a fiberglass bumper cover but that's the only way to lose that much weight and still have the thing look like a Corvette. Alot of the bumper is to help shape the stock urethene cover over it. The fiberglass is already stiff and won't distort over bumps or during highway driving. Plus you don't need the original taillight mounts that are bolted to the rear bumper, you can just drill your own holes and mount it directly to the fiberglass cover.
I had my muffler guy cut off the brackets from the air reservoir. I picked them up this afternoon, and bolted everything back together. The front bumper support is now connected to the frame and radiator support in four places. It is very solid. But when I look down into the area where the reservoir was, I am just amazed at how open the area appears now. Cooling has got to be enhanced, because there is so little in front of the radiator now. I'm finished with this mod, and I highly recommend it if you are serious about losing weight.
Originally Posted by Vette Gator
Now, if we can just figure out what to do with two vacuum tanks without any brackets. Mine is still taking up space in my garage.
I read somewhere in here that it's not needed, but I can't find the thread. Taking it out saves a ton. I already rerouted my vacuum lines to operate my headlights without it. That was too easy. I guess getting this thing out is the hard part. I'll work on it some more tonight.
I would NOT remove it and leave the front end unsupported.
I do agree with you that people who are not going for a racing car should leave it in place.
I am slowly converting my car to a race/street car.
Bee Jay, What are your goals? It doesn't make sense to remove all these components unless you intend to get serious about racing.
It weighs 39 pounds and you need it to maintain the integrity of the front end. I removed mine, acid dipped it and drilled it full of holes and got it down to 19 pounds easily and reinstalled it. Also there is a large rubber and steel backing plate for the liscense plate. Removing these saved alot of weight.
Edit: Norval, I just looked at your picture again. Where is your radiator support? That piece is key to keeping my front end solid. I guess there is more than one way to skin a cat.
If you leave the outer bracket and front metal bracket there will still be some support left.
I never knew that removing this air tank would save 40lbs till I read it here. I learned here that I could replace the iron crossmember and rear end cover with a post 80 aluminum bat wing. This forum rocks.
But its not like these cars are that safe to begin with. Definitely safer than riding a motorcycle.
#33
Sometime i feel i'm leading some of you astray with my ideas. Just want you to understand that you are accepting some level of safety compromise when taking all that structural steel out.
#35
Originally Posted by Twin_Turbo
There...fixed it for you
Bee, heres my lightening list.
Corvette weight reduction.
1. Removed front vacuum bar 31 pounds
2. Removed rubber plate behind bumper 13 pounds
3. Cutout steel behind license 5 pounds
4. Replaced brass radiator 31 pounds with aluminum 19 pounds net 12 pounds.
5. Aluminum heads save 44 pounds.
6. Remove A/C compressor 50 pounds
7. Aluminum intake 15 pounds
8. Aluminum driveshaft 10 pounds
9. Remove spare 40 pounds
10. Aluminum water pump 8 pounds
11. Aluminum calipers 40 pounds
12. Fiberglass spring 30 pounds
13. Seats 30 pounds
14. Aluminum wheels 20 pounds
15. Tube exhaust manifolds 15 pounds
16. Stainless flex exhaust 15 pounds
17. Remove catalitic converter 15 pounds
18. Lighter mufflers 10 pounds
19. No air pump 10 pounds
20. No T Tops 25 pounds
Possibilities
1. Aluminum block 100 pounds
2. V6 aluminum engine 200 pounds
3. remove radio 12 pounds
4. Aluminum rear end 57 pounds
5. Aluminum half shafts 10 pounds
6. hack up hood 10 pounds
7. Light weight sway bar 15 pounds
#36
Rust is a modification no one else utilizes. Its my competitive advantage.
13. Seats 30 pounds
Possibilities
13. Seats 30 pounds
Possibilities
How much does your car weigh?
I did not know switching radiators would lose so much weight. I got more work to do. I wonder if anyone on the forum has built a 383 aluminum engine. I wish I was rich enough to do that.
#40
Wow! This is an old thread. But here is another one:
https://www.corvetteforum.com/forums...post1570560887
You can find most of my old posts by typing "Bee Jay" in the search box.
The car is now 3000lbs, and I drive it at least twice a month, but I don't post much or lurk anymore. I also drive a C4 94 Vette now too. I spend my spare time on Facebook now. I think the Corvette forum was our social medium before facebook was even invented. I made lots of friends here. Hello everybody. I guess I disappeared like Norval Wilhelm did. But I drop by occasionally.
Bee Jay
Bee Jay
