427 runs really rich
Old Sep 30, 2006 | 10:49 AM
gghg's Avatar
gghg
Default 427 runs really rich
Folks, I have a 69 with a 427/390 hp AT, with a qjet. The engine runs really rich, the plugs are BLACK and loads up at idle and stalls. I have to 2 foot drive and when I start off lots of black smoke from the pipes. I checked the choke and is fully opened. It has a re-built carb. This all started just after I replaced the dist points with the crane cams XR-i Points To Electronic Ignition kit. Co-incedence? or is there something else going on.
Old Sep 30, 2006 | 10:52 AM
Bob Onit's Avatar
Bob Onit
If it ran OK with the rebuilt carb before you switched to the Electronic unit then I guess that is the problem
Of course timing can be an issue as well
Old Sep 30, 2006 | 11:09 AM
gghg's Avatar
gghg
I thought of going back to see if that is the problem. Any suggestions for a initial timing? I have it set at 12 degrees.
Old Sep 30, 2006 | 04:29 PM
zwede's Avatar
zwede
I'm thinking the needle is sticking and the carb is flooding. Or you have an aftermarket pump that puts out more pressure than stock overwhelming the needle.
To 427 runs really rich
