Brake conversion
Old Oct 3, 2006 | 11:57 PM
SMH's Avatar
SMH
I will try them thanks
Old Oct 4, 2006 | 07:25 AM
rastadr's Avatar
rastadr
going to the hydraboost was a great improvement. changed the character of the car and stops like never before, even with a good working system.
Old Oct 4, 2006 | 09:13 AM
Durango_Boy's Avatar
Durango_Boy
He'd have to add a power steering pump for Hydro. I'm a big advocate of Hydro as well, but for his application he has to maintain a non-power car.
Old Oct 4, 2006 | 11:08 AM
SMH's Avatar
SMH
Correct
Old Oct 4, 2006 | 12:27 PM
Durango_Boy
You never did say if you had considered a small electric vavuum pump to aid the engine's vacuum for the booster. May make the difference enough to save you work of swapping to manual.
Old Oct 4, 2006 | 02:08 PM
SMH's Avatar
SMH
I looked at them and decided against it. But I may have to reconsider.
Old Oct 4, 2006 | 02:12 PM
Durango_Boy
The only place I have ever heard of them being used is in race applications so I imagine they make one that would fit your needs. Perhaps a racing forum member would have more incite.
Old Oct 4, 2006 | 05:40 PM
BBShark's Avatar
BBShark
St. Jude Donor '05-'07
Electric vacuum pumps have been used in production cars, 80's Cavaliers for one. If you go the vacuum pump route, look at Gast ambulance vacuum pumps, that is your best deal for 12V vac pumps.
Old Oct 4, 2006 | 06:30 PM
Durango_Boy
Cool. I was gonna look into a vac pump before I switched to Hydro. I may still depending on the cam I end up using. Great source.
