suspension advice
Old Oct 3, 2006 | 07:02 PM
69autoXr's Avatar
69autoXr
Originally Posted by Durango_boy
Well, in my car's defense...it has not been driven since the cut. I put the wheels back on, and used my body weight to compress the suspension to a load. After doing this, the toe seemed fine. Maybe it was a little over the other way before I started and this corrected it. I just never noticed a toe in/out problem.
So your 1.5" drop figure is also without driving the car?
Old Oct 3, 2006 | 10:25 PM
tamvette68's Avatar
tamvette68
thanks flynhi....was really wondering if you get what you pay for in shocks........
Old Oct 3, 2006 | 11:01 PM
flynhi's Avatar
flynhi
I have tried Koni, Tokico, KYB, KYB GR-2, Delco, Monroe and Bilstein HD and Sports. Bilstein HD seems best for my SB with composite springs.
Old Oct 4, 2006 | 09:34 AM
Durango_Boy's Avatar
Durango_Boy
Yep, I measured after I squished the suspension, and tightened everything. I will drive it and measure again, but a forum member that suggested the cut said he didn't experience any more drop after driving once he compressed the suspension.
Old Oct 4, 2006 | 10:09 AM
rihwoods's Avatar
rihwoods
Originally Posted by tamvette68
Feeling the need to jack it back up, what can I do initially to keep the tires where they belong? Springs, shocks, rear sway bar, strut rod, etc.? Can shocks alone give it a better ride?? If so, what works best on a weekend cruiser? Does it all have to be done at one time??? Would like to enjoy the fall rides.
I went with a Guldstrand 7 leaf..(stiffer than stock F41) and Bilstein Sports...very firm,but bumps no problem at speed....
It is possible your stock leaf spring has lost most of it's arc....is it flat ???
The new 7 leaf is also 1 1/2" shorter than stock,allowing for more tire clearance...you can also order composite spring shorter from forum vendor...
Old Oct 4, 2006 | 10:34 AM
Durango_Boy
How much of an arc is recommended before the leaf is replaced?
Old Oct 4, 2006 | 10:43 AM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
when your exhaust and or spare tire carrier is draggin on the ground, at least thats when i changed mine
Old Oct 4, 2006 | 10:45 AM
Durango_Boy
Great way to measure...only I have sidepipes and no spare or carrier. If it flat it should be replaced?
Old Oct 4, 2006 | 10:48 AM
sweethence's Avatar
sweethence
If you like i can go out and measure the height from the top of the tire to the bottom of the wheel opening... the new spring ( 9 leaf in my case) gave me almost two inches of additional height even after settleing, car sits perfect now
i have heard of people having their springs re arched, and if you want to keep the original springs sure, but a new rear spring will only run you 120-150 buck for the steel version which I prefer of the composite (purely personal preference)
also when you look aqt you rsings as the car is sitting on the gorund, does it look flat ?
Old Oct 4, 2006 | 10:51 AM
rihwoods's Avatar
rihwoods
I would say if spring is flat..no arc...my 78 is borderline...will need to replace it soon...arc on it is about 1/2" over it's length...
..or as sweethence says...hitting your spare tire tub...
...some guys adjust rear wheel camber to overcome sag...but that is just a band aid...
Rich
Old Oct 4, 2006 | 10:54 AM
Durango_Boy
No need to measure...I do still have some arc, I would say abotu an inch over flat. Guessing...it'll need to be replaced soon, but it seems to sit high on the wheels. I will likely go with larger tires in the rear when I upgrade the shoes in a year or so.
