Second thoughts on a cam choice.
I don't race except the occassional light to light, and I don't spend a lot of time at high RPMs. The longer stroke and stock crank will not have enough of an effect on my purpose for this motor to require a multi thousand dollar change of plans. The machine work I have yet to do will cost less than $200. I checked. Hmm...$200 vs $2000. I think that this motor will last me a LONG time the way I take care of them and mind their operation.
I like all the suggestions, but getting razzed for something I NEVER asked about? I asked about a cam, and I got good feedback and I thank everyone for it. Then I started getting heat because I'm not building a NASCAR engine. For Christ's sake just let me build my lower RPM cruising motor.
These things will be done, as I said. Thanks for the confidence. I have built engines before and have gotten to know the guys at the machine shop well. Yes, the load will be greater, but they are confident as well as I that what I have planned will turn out fine and run hard and strong for longer than it will take for me to get bored and want a new motor.
Sorry I missed this question man. Okay, don't go off my $200 total for all the work I"m having done. J D at the machine shop is hooking me up, and I'm getting $500 worth of work for $200. Long story.
Anyway, most of the local machine shops will do a full balance for $200. Now, that requires you to have just about everything you would need to build the bottom end. When you take it in, have everything ready to take with you. Crank, balancer, flywheel, rods, rod bearings, pistons, pins, rings, and $200.
I'm having them balance everything, condition the rods, and install the new pistons. I'm taking in the new rod bolts, which usually adds $60 to your total cost...I got them for $35.
