Speedo Gears
Old Oct 8, 2006 | 09:31 AM
jlelec's Avatar
jlelec
Default Speedo Gears
Any one happen to know the correct speedo gears required for a stock 81 automatic with a 200R4? The ratio of the rear end? According to the 81 GM brochure the final ration is 2:87. This doesn't sound right. Any help??
Old Oct 8, 2006 | 09:36 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Yep. 2.87 is right on the rear end ratio. Don't know the speedo gear.
Old Oct 8, 2006 | 09:51 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Funny that you mention this. I've got the same problem.
My current gear is reading between 5 and 10 MPH high.
I also think that you need to include your tire size to get the right gear. There is a link to a calculator on the BTO site but I've never been able to make it open.
Edit: I was just able to make the link work and here it is:
http://www.2004r.com/speedoCalc/speedocalc.shtml
For my 81, with 255 60 tires, the drive gear is a 13 tooth and the driven gear is a 28 tooth.
These are available through Bowtie and on EBay.
Old Oct 8, 2006 | 11:45 AM
redwingvette's Avatar
redwingvette
The link works for me.
You do have know the tire height and gear ratio:
Drive Gear Driven Gear
13 tooth 29 tooth
26.5in tires
13 tooth 28 tooth
27in tires
Old Oct 8, 2006 | 09:30 PM
jlelec's Avatar
jlelec
13 tooth 29 tooth
26.5in tires
13 tooth 28 tooth
27in tires
Thanks for the help! I ordered the right gears from Bowtie..
To Speedo Gears
