Block fill
Old Oct 8, 2006 | 11:05 AM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Default Block fill
what is the deal with block fill?
Old Oct 8, 2006 | 02:20 PM
Twin_Turbo's Avatar
Twin_Turbo
you fill up till the freeze plugs and then have the block machind, not the other way around
The block rock supports the cyl. bores, allows you to grind on the lower block rail to clearance without breaking into the water jacked. There are more benefits like the ability to run the water and oil temp much more seperate from each other.
Old Oct 8, 2006 | 03:51 PM
gbak's Avatar
gbak
Is there are any problems with engine cooling if filling the block up to the freeze plugs on a street driven car?
Old Oct 8, 2006 | 03:58 PM
Guru_4_hire
Cruise-In V Veteran
That is a point of contention, from google is telling me. I am going to give it a try.
Old Oct 8, 2006 | 04:05 PM
gbak's Avatar
gbak
You will gain some hp if the oil will be warmer, don't know if it's worth it on a street driven car.
Old Oct 8, 2006 | 04:56 PM
Twin_Turbo's Avatar
Twin_Turbo
No, no cooling problems if you fill up to the freezes plugs. The bulk of the heat is transferred in the head and the upper most part of the cyl. wall.
Old Oct 8, 2006 | 06:58 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Hmm...I'm wondering if this might not be a good idea for my .060 over 400 block...
Old Oct 8, 2006 | 07:28 PM
Guru_4_hire
Cruise-In V Veteran
Probably. That has been the most common app I have found on the internet.
Old Oct 8, 2006 | 08:06 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
What happens if you do it to a block that's already been machined?
Old Oct 8, 2006 | 09:27 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
I would think that you'd at least have to have the bores checked for roundness & rehoned.
Old Oct 8, 2006 | 10:10 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
That's pretty much a given, anyway. It needs a line bore.
To Block fill
