Does this frame look solid to you? (pics)
Old Oct 11, 2006 | 08:41 AM
kylelm's Avatar
kylelm
Default Does this frame look solid to you? (pics)
Does this frame look solid enough for a project car? I think it does, but I just want to make sure.
Old Oct 11, 2006 | 08:55 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by kylelm
Based upon what I can see, it looks okay to me. Typical Corvette. What puzzles me is what looks like a spacer on the spring mount bolt. What's up with that?
Old Oct 11, 2006 | 10:25 AM
kylelm's Avatar
kylelm
I dont see it. Where are you talking about?
Old Oct 11, 2006 | 10:39 AM
lars's Avatar
lars
Frame looks good - usual surface corosion but no holes. There is a spacer on your spring mount bolt that someone has put there to change the rear ride height - the rear spring may be sagging, so they used a spacer to raise the rear.
Old Oct 11, 2006 | 10:47 AM
71rdster's Avatar
71rdster
I don't think the exhaust is going to last very long, but frame looks pretty good.
Old Oct 11, 2006 | 11:12 AM
copter's Avatar
copter
Old Oct 11, 2006 | 11:23 AM
kylelm's Avatar
kylelm
I want side exhaust anyways..
Old Oct 11, 2006 | 11:53 AM
Red70vette's Avatar
Red70vette
I see no major issues with the frame. Have you checked the bird cage?
Old Oct 11, 2006 | 11:59 AM
redvetracr's Avatar
redvetracr
and the frame "kick up" where the trailing arms slip into the frame....that and the bird cage are the most troublesome spots.
...redvetracr
Old Oct 11, 2006 | 12:19 PM
kylelm's Avatar
kylelm
i have requested more pictures of the frame where the traling are meets and some pictures of the birdcage. I will post them when i get them (I am told it will be late tonight).
Old Oct 11, 2006 | 02:31 PM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
looks like bubba was messin with the ride height
Old Oct 11, 2006 | 04:21 PM
kylelm's Avatar
kylelm
What is that broken in the circle?
Old Oct 11, 2006 | 04:26 PM
TedH's Avatar
TedH
In my opinion, it looks pretty darn good!
TedH's Avatar
TedH
Tire carrier (plastic cover).
Old Oct 11, 2006 | 04:29 PM
TexSon's Avatar
TexSon
Spare tire cover.
Old Oct 11, 2006 | 05:07 PM
Wrencher's Avatar
Wrencher
Not so much broken as skidded off! This is the last thing that hits the ground as you pull into angled driveways...
Old Oct 11, 2006 | 07:02 PM
RPOL68's Avatar
RPOL68
That broken tire carrier looks like it's from a tow. Happened to mine when I had a rear wheel bearing go south and had the car towed home. (prior to sliding bed tow trucks) That was one of my first fiberglass repair projects. The damage looked just the same.
To Does this frame look solid to you? (pics)
Old Oct 11, 2006 | 07:11 PM
71rdster's Avatar
71rdster
I have an extra tub that is better than that one, Not perfect, but cheap. The V-strap took more hits than the tub, so I have separated them. Got NOS pieces off of ebay for my car, but I'm not sure that I can use them either. Fairly steep driveway.
Old Oct 11, 2006 | 07:12 PM
gator79's Avatar
gator79
hey thats how my spring and carrier looked, fixed the spring need to fiberglass the carrier.
Old Oct 11, 2006 | 07:19 PM
Vettkeeper's Avatar
Vettkeeper
Do you have any pic's of behind both rear wheels where the trailing arms connect and the frame kicks up? This is a spot where a lot of rust trouble is found. Other wise it looks pretty good.
