what the hell just happend?
Old Oct 18, 2006 | 04:46 PM
another-user's Avatar
another-user
Default what the hell just happend?
i just went out for a quick drive, had to go pick my sister up at school. no more then 10 miles round trip.
the car was running pretty good, little rough at start but it got better as it warmed up.
im comeing back home and make a nice, easy, left turn at about 10, 15mph tops in 2nd gear. all the sudden i hear a VERY loud poping sound. gauges all read normal, and everything felt pretty normal. car didnt feel like it shook, bounced, jerked, or anything like that.
i checked my rear view mirror and asked my sister if i hit something in the road. she saw nothing, and i saw nothing when i turned and nothing was behind me.
i get home and all the guages are still reading normal and the car still feels normal. i parked it and went inside for 5 mins while i waited for it to cool down a bit. i come out and theres a small puddle of milky oil right under the harmonic balancer. probably about twice the size of a watch face.
i looked over the motor and everything seems to be ok, but that doesnt mean everything realy is.
Old Oct 18, 2006 | 04:50 PM
TedH's Avatar
TedH
Sounds like water in the oil? The popping could have been the engine overheating; got so hot that the engine was mis-firing. I'd also pull the dipstick and check for oil condition; water in oil?. I had a similar event happen and found the engine had overheated when my heater hose disintegrated. Popped the hood and steam, rad fluid all over the top of the engine. Fortunatley, I didn't blow any head gaskets, crack the block or warp the cyl heads; a new thermostat (while I was at it), heater hose and new coolant fixed it right up (my 69 L46).
Old Oct 18, 2006 | 04:56 PM
kevinator80's Avatar
kevinator80
Are you telling us that you saw a spot of milky substance under your engine compartment and your first thought was to post here instead of pulling the dipstick? Good luck to you my friend.
Old Oct 18, 2006 | 05:00 PM
68RATVT's Avatar
68RATVT
Wow, ease up on the guy, what's wrong with asking the forum, not everybody is a gear head. That's what we are hear for...
Old Oct 18, 2006 | 05:02 PM
Twin_Turbo's Avatar
Twin_Turbo
better hope you don't have a mayonaise filled engine...doesn't sound good
Old Oct 18, 2006 | 05:09 PM
Little Mouse's Avatar
Little Mouse
don't know what the loud poping was but if your oil is milky looking
could be a blown head gasket to a cracked head or block.
Old Oct 18, 2006 | 05:43 PM
another-user
ok, now that the panic has subsided and have had a moment to actually look it over, i MAY have jumped to conclusions on the milky oil.
i didnt notice it at first, but the ground is a little wet still from last nights rain. it may (hopefully) just have been the water on the ground that mixed with the oil and is forming the milky colord oil.
and your also right, im not a gear head. gear head in training, yes, but thats about it.
and my dad just got home and we took a look at things.
he syas i was right in jumping to conclusions about the milky oil, it just mixed with the water in the ground.
as of right now we cant find anything wrong or out of the ordinary. it started right up and ran real well. oil pressure was good and steady, and water temps were fine.
right now were just going to keep a good eye on things, and write off what happend as a freak accident. if something starts acting up again then well take a good long look at things.
Old Oct 18, 2006 | 05:56 PM
NHvette's Avatar
NHvette
Kinda sounds like a suspension issue.
I'd inspect all the front suspension components ... then move on to the rear.
luerja's Avatar
luerja
maybe...just maybe you have a broken or very loose motor mount and the engine lifted ?
Sorry but thats my best guess
Good Luck,
jim
Old Oct 18, 2006 | 10:45 PM
austvette's Avatar
austvette
I’m not sure if you have a fibreglass rear spring or not? But i was in almost the same situation however I didn’t have the milky oil under the car. Turned out that the tiny crack I had in my rear fibreglass spring had just gotten a bit bigger. Not to bad though the car still sits up at the correct level when no one is in it just sinks a bit when you get in. Needless to say iv got a spring on order but it all takes so long to get to Australia.
Old Oct 18, 2006 | 10:53 PM
onaqwst's Avatar
onaqwst
check the rear t-arms where the bump stop is at..... see if the metal is bent down........
i had that issue when i would go up driveways on an agle...the axle shaft was hitting the bent down bump stop and it sounded like a series of pops.....
b
Old Oct 18, 2006 | 10:59 PM
speedreed8's Avatar
speedreed8
you said it popped when you turned, do you think it could be your positrack unit in the rearend.
Old Oct 18, 2006 | 11:21 PM
another-user
i wont know more till maybe tomarrow night, friday more likely.
all depends on what the weather wants to do for the next couple of days.
Old Oct 18, 2006 | 11:40 PM
kevinator80
Would you rather me tell him to drive down to the local service center to have it checked then? I didn't think so.
Old Oct 19, 2006 | 12:25 AM
68RATVT's Avatar
68RATVT
You didn't offer any advice, just a smart *** comment, useless...
Old Oct 19, 2006 | 01:06 AM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
the milky oil thing is still suspicious to me. water and oil don't turn milky just by coming in contact (ala oil leak on a rainy driveway). emulsified oil is a result of water being circulated in the oil system while the engine is running.
that being said, it does sound like a suspension problem.
Old Oct 19, 2006 | 09:26 AM
litevette's Avatar
litevette
Get him 68RATVT!!!
To what the hell just happend?
Old Oct 19, 2006 | 09:33 AM
FB#1's Avatar
FB#1
I agree that the oil would sit on the water and it wouldn't mix and give you that milky look in that short of a time. I'd also look at getting that leak fixed if its dripping that much in that short amount of time.
Old Oct 19, 2006 | 09:35 AM
kevinator80
And just what did you contribute to the discussion?
IMO he got what he asked for. If you want good advise give good information for us to work with. I don't know it all and if I do have a problem with my car I first take the initiative to check atleast a few things on my own.
And yes, I have been known to be a smart *** and I prefer that to the exact opposite.
Old Oct 19, 2006 | 09:37 AM
kevinator80
Originally Posted by litevette
Get him 68RATVT!!!
Sorry but I'm done with this.
