I'll be the first to admit I'm very new to figuring out compression, and while I've done some reading in the area I can say I still feel a bit lost. Anyway, after getting the bottom end of my 400, (405), built, I began worrying a little about it's compression and was hoping someone could help me get a rough estimate of where this engine stands on comp. It's a 400, bored +.020, with a 10/10 stock crank and stock rods with Speed Pro pistons, and an LT4 Hot Cam. The heads being used are basically stock '89 350 heads...I don't have the castings handy so I can't speak for that yet...I'll look in the morning. Do you need any more info to figure this out? Here are the pics of the finished rotating assembly with #1 at TDC. The piston flat is just a hair or two under the deck height.
Unless you have some really small combustion chambers,I doubt you will have 12.1,I am with out knowing all the details,I am going to say around 10.1 give or take a 1/2.
I doubt you like that hot cam in a 405,It wasn't that great in a 350.
Okay, I'll get to work on that tomorrow. Can someone walk me through CCing the heads as I've never done that either. Thanks so much.
The chamber has to be clean, no carbon buildup, and assembled with valves & spark plug.
Place head upside down and perfectly level. Get a 10 cc burette from a hobby shop. Water with a drop of dishwashing liquid to remove surface tension. Add water until the chamber is full. Many like placing plexiglass on top so they know when the chamber is full and add water through a hole in the plexi.
Okay, I'll check intot hat, and report back with those numbers and the dish sizes too.
awsome advice. I didn't know how to do this either.
The plexi seems like the most accurate so you don't get a "bubble" affect which would add more volume then whats really there.
Durango, take some pics of this process and post. I'd like to see how it all works out.
I learned my one thing today....going to rest my head on my desk just for a second....worked on the car all night, only 2 hrs of sleep.
Me too. I got my bottom end finished, timing installed, and a few other details. Got to get a few hours ago. I'll take some pics when I get to doing it a little later today...as I want to know the comp before I install the heads. I also have to figure out this cam button problem. The one I have fits, but the retainer doen't fit, and I have never installed a roller cam button before.
How much trouble did you have getting the factory dogbone lifter setup to work? I gave it a bit of a shot but didn't have the machine tools needed to get the tops of the lifter bores perfectly flat. It doesn't take but a couple of degrees out to tilt the dogbone into a bind.
The cast on my 400 block made it a little harder, but all I used was an air compressor, a die grinder, and a could good bits. A little time, and they fit right down flat. Drilling and tapping the holes for the spider bar studs was pretty easy too once you mark the holes. I would help anyone who needs it, and while the startup will determine how great the conversion is I've heard everyone likes it over the more expensive link bar style roller lifters.
