Converting from smallblock to big block
Old Oct 22, 2006 | 03:10 PM
Malice 1's Avatar
Malice 1
Originally Posted by Durango_boy
Say he finds a small block car with an auto, and the 350 is shot. It'd be several thousand cheaper than a big block manual rigth? That's a huge difference when the drivetrain is gonna be changed anyway. Drop in a big block, a 5 spd, and some pedals and loankages and you have the car that was sought after fromt eh beginning, saving a few thousand along the way...and you have a moveable cross member.
So, lemme get this straight....
cars equipped with auto trans had a moveable crossmember, where the manual cars had welded in crossmembers?
Why is it soo hard to deal with a welded in xmember? I think it would be easier to do that than it would be to install a 3rd pedal, linkages, etc...
You guys know best, so tell me the best route. I planned on using the 350's tranny until we really needed a T-10.
Old Oct 22, 2006 | 03:12 PM
Durango_Boy's Avatar
Durango_Boy
Well, Batman will tell you best about the conversion since he's doing it to his auto '77. The car is already set up for the pedals, you just have to install them.
As far as the cross member, a bolted in unit gives you the freedom and option to move it based on what trans you use. A welded cross member would work just fine until you had to move it, and then you;re stuck with trying to cut it, move it, and re-weld it.
Old Oct 22, 2006 | 03:19 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
The pedal bracket is the same, it's just a matter of swapping the pedals. Numerous posts here detail auto-to-manual swaps. Posts by Norval and Bernie are excellent sources of information.
Muncies can be just as strong as T-10s. Some later C3s actually used ST-10s for four speed manuals. Most people doing conversions are going with 5 or 6 speed transmissions to get overdrive.
Everything I've read says that the welded crossmember is a major pain when it comes to doing things like changing the clutch.
It's all a matter of what you want to do with the car. I'd recommend searching old posts thoroughly before making a decision. Most C3 issues have been hashed out pretty well over the years. The archives can be accessed through "advanced search."
Old Oct 22, 2006 | 03:38 PM
Vette-73's Avatar
Vette-73
if you want a big block then buy one and enjoy the ride.
Old Oct 22, 2006 | 03:39 PM
Durango_Boy
I'm sorry but that was RUDE and UNCALLED for...no matter what the intention.
Old Oct 22, 2006 | 04:15 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Originally Posted by Vette-73
if you want a big block then buy one and enjoy the ride. Later
What's your problem?
Old Oct 22, 2006 | 05:29 PM
TEXASRANGER's Avatar
TEXASRANGER
HOOK-EM HORNS
St. Jude Donor '08
I really wish I had a removable cross member in my stantard. We installed the tremec witht he engine out but when I have to replace the clutch I am going to have to remove my headers, side pipes, all the necessary stuff to remove the engine, like radiator etc. I am going to have to pull my engine up and move it forward to get the trans out. Or cut and re-weld the cross member. I went with hyro clutch and if I had started with a automatic car it would have been way easier. Only about an hour or less to change out the peddles.
I am sure the engineers who designed our C-3's never thought we would be putting in things like 502's, 5 and 6 speeds, etc.
Old Oct 22, 2006 | 05:47 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
I hate chrome bumper/big block snobs.
Yep, Buy an original big block NOM and get toasted by every new performance car on the road.
Old Oct 22, 2006 | 06:14 PM
Vette-73's Avatar
Vette-73
I am with you on this one, Any moderen small block will waste any so-called big block dia-nosore or should I say bore
Old Oct 22, 2006 | 06:31 PM
Durango_Boy
No profile? I'm guessing you have a '73. What is it you have against motor swaps?
Old Oct 22, 2006 | 06:46 PM
TEXASRANGER
HOOK-EM HORNS
St. Jude Donor '08
We just don't keep them stock........we change out to 502's etc. I whooped my friends 04 C5 this weekend...no contest. Can I whoop a new Z06, I don't think so, but it an't no small block. If I go to slick's etc, I might whoop him though.
Old Oct 22, 2006 | 07:02 PM
SuprJames's Avatar
SuprJames
You're an LS1 guy and you're putting a big block in the car???
Why don't you get a SB automatic and put a LSX mated to a T56 in it?
Old Oct 22, 2006 | 07:17 PM
  #33
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
My Troll detector just went off.
Old Oct 22, 2006 | 07:20 PM
  #34
Durango_Boy
Who's this troll, me or Vette-73?
Old Oct 22, 2006 | 07:24 PM
  #35
Jughead's Avatar
Jughead
St. Jude Donor '09
sorry, not you.
Old Oct 22, 2006 | 07:26 PM
  #36
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
M-1-1 has been dialed...
Old Oct 22, 2006 | 07:35 PM
  #37
turtlevette
Exactly,
So just start with a beater small block automatic car and drop the 502/572 and 6 speed in.
I would consider the new Z06 a small block. Ain't it the same LS-2 block just stroked?
That's gonna be the next hot swap cause you don't have to put that enormously high hood to make it fit. A true sleeper.
To Converting from smallblock to big block
  #38
Malice 1's Avatar
Malice 1
I've never been underneath one of these cars before, but since I want to stay manual, I don't forsee the solid xmember being a huge problem for me. Please remember that this car is not for me. My buddy has no desire for a T5 or T56. He also has no desire for an LS1, or a killer smallblock.
Again, does anyone know off hand if there is a kit out there which has brackets and misc. parts for this swap? The link earlier in the thread had some great info, I just want to be able to find parts easier.
Vette-73, thank you for your technical expertise. Would you please delete your posts?
Old Oct 22, 2006 | 07:49 PM
  #39
Jughead's Avatar
Jughead
St. Jude Donor '09
The alt & PS brackets can be purchased via Paregon reproductions or other vendors. I used a stock alternator bracket for a 69 BB. The pullies are sometimes found on ebay or the vendors, Ecklers, Volunteer Vette, Zips etc.
Old Oct 22, 2006 | 07:51 PM
  #40
norvalwilhelm's Avatar
norvalwilhelm
Need the low mount engine mounts. Will have to modify the exhaust. Hood clearance might be a problem. PLENTY COOLING. If using a HEI it will hit your windshiled wiper motor and you will have to route your wires according. Need heavy duty half shafts, non greasable for strength.
I converted a 75 and didn't run into any of these problems. Didn't know I could get low motor mounts? I just used the ones right off the stock 350.
Modify the exhaust? I bought a set of cheap Heddman headers and they fell right into place. Good fit and lasted me 15 years.
I did also use the 350 distributor, the front coil springs and the stock rad for a number of years before upgrading.
I used 280 pound springs for almost 20 years with various bigblocks and loved them.
the 75 comes with the larger half shafts but again I used greasable u joints and never had a failure in 20 years and that included my nitrous motor, slicks and my present blower motor.
The swap is very simple and alot of the smallblock parts work for the bigblock.
good luck
Forgot hood clearance. I used the high rise LS6 intake and had to clean up the underside of the stock hood and run a drop base air cleaner and a 2 inch element.
