Installing Drag Vette Kit, Need help
Old Oct 22, 2006 | 12:28 AM
brian76's Avatar
brian76
Default Installing Drag Vette Kit, Need help
I got a new Drag vette kit, but I can't get the old strut rods off where the trailing arm connects. I need to know if the shock/strut bolt separates completely from the trailing arm or not. I put the castle nut on the strut stud and hit it with a hammer but it's in there solid and won't budge. I was thinking that maybe the strut rubber bushings might be holding it up. Since I'm replacing the bushings anyway, could I get a torch and burn them out of there? Help!
Old Oct 22, 2006 | 11:07 AM
Red 69's Avatar
Red 69
brian, this thread will be of some help. http://forums.corvetteforum.com/show...ut+rod+removal
I have done this job twice and it it can be a PITA. The shock mount is usually frozen to the steel liner of the rubber bushing. If you are replacing the struts with 'smart struts' you night consider cutting the strut ends to expose the rubber bushing, remove the rubber to expose the steel liner and cut it off the shock mounting bolt.
Another member used a two jaw puller connected to one fork in the bearing assembly housing and pushed the bolt out. There have been many innovative methods described in this forum to tackle this job. I used the caveman approach and with oxy-acetelene burned the rubber bushing while heating its liner until the bolt could be driven out. Do this in a well ventillated space, as the smoke will choke you out. If you choose this method, be sure to reverse the castillated nut over the thread to protect it when hammering. If you get too aggressive with the hammering you can damage the arms of the bearing assmebly and that will cost you. Ecklers sells a special nut for the hammering job, but I have not found it necessary. On reassembly use antisieze for the next time.
Old Oct 22, 2006 | 11:48 PM
brian76's Avatar
brian76
Thanks for the info- I don't know how or have access to a cutting torch, but I do have a 2 jaw puller. If that doesn't work, I have an 8 lb sledge handy......
To Installing Drag Vette Kit, Need help
