dumb question about rotors
Old Oct 23, 2006 | 07:10 PM
BLorah's Avatar
BLorah
6th Gear
Default dumb question about rotors
Hi, I am a new member with a dumb question regarding the removal of the rear rotors on a 1973 Vette. The calipers are off, how do you remove the rotors? Also, how bad is a cracked upper leaf spring mount on the rear differential cover? Should the cover be replaced? I'd appreciate any help with this.
Thanks!
Bill
Old Oct 23, 2006 | 07:29 PM
Duke94's Avatar
Duke94
If they are the originals, they will be rivited on the spindal and you have to drill out the rivits. If the rivits are already removed, you may have to back off the parking brake shoes to be able to pull the rotor/drum off.
P.S.: Fill out your profile so we know who you are. Thanks.
