L36 intake
Old Oct 25, 2006 | 10:08 AM
jack 69's Avatar
jack 69
Default L36 intake
I'm on my 5th set of intake gaskets. using felpro and cortec gaskets... vacuum gauge indicates leak at idle, runs good at 1200 rpm on up.. a check for leeks on the top side and found nothing... a compression test shows 180 on all cylinders.... i'm thinking the leak is on bottom side of the intake, but the gaskets i take out look like they are sealed.... is there a way to check the lower side?
1000 miles on fresh engine, standard trans and brake, stock intake, new holly 4175, 8 deg timing 34 total, comp cam and lifters....
Old Oct 25, 2006 | 04:34 PM
BigBlockk's Avatar
BigBlockk
How do the plugs look? What is the idle vacuum?
Unhook the PCV valve and use a manometer to see if there is still vacuum in the crankcase.
BigBlockk
Later.....
Old Oct 26, 2006 | 12:04 AM
73, Dark Blue 454's Avatar
73, Dark Blue 454
The L36 intake has a trough in front of part of the carb mounting pad to which exhaust heat is routed to the bottom of the carb to quickly warm an engine.
If you don't have the period correct q-jet, a part of this trough is exposed and the carb will pull outside air from this opening. Check for a leak just below the carb on the driver's side up by the front corner.
If that's not it, tell us what your vacuum needle is doing,..is it drifting?
Old Oct 26, 2006 | 12:59 AM
jack 69's Avatar
jack 69
Default L36
the carb is a Holly spredbore, so the cross over is covered... vacuum is 14 to 12in..... the cam is nothing to wild..... i think...
Old Oct 26, 2006 | 01:28 AM
jack 69's Avatar
jack 69
Default Plugs
i pulled the plugs and have a mix of color... most are ltbrn & wht with some gray... one, #3 has oil but not enough to foul... all of the arc zones are clean... some have oil on the threads but don't look bad....
manometer... i have one but it will be a day or two befor i can try that...
thanks!
To L36 intake
