I'm seriously considering trimming the tips... just wondering how true what Stahl said is. I could see where it could make a couple of horsepower difference; probably not enough to justify changing the looks of the car. I do remember Stahl talking about how much it could change the flow characteristics of the exhaust.
What is interesting is the length of the straight pipes he made for me - they are only about 7" before the turn-out starts with a total length of about 11.5". It will be interesting to compare these short pipes to my current set-up without the baffle in them.
I was taking a look at some of your pics and noticed you were using the u-type straps on the rear u-joints. If you are planning to drive it hard you may consider upgrading from straps to machined type, which came on the big block cars and LT-1s. and/or install some safety loops from dragvette. just my 02 to save you from doing major fiberglass damage if one of those straps break.
I've been seriously considering the safety loops from dragvette, but wasn't aware of the machined type straps - I will have to look into those.
Results of baseline chassis dyno run from yesterday. I was extremely impressed with the performance of the baffles. We ran two runs with the 3.5" sidepipes and baffles - near identical (within 2 hp and 2 ft/lbs torque). Next I slipped off the sidepipes and put on the 3" short "race pipes". The short pipes only made an additional 12.8hp, but a little more torque - 23.6 ft/lbs.
The short pipes were extremely loud... I actually had to step out of the garage for the run. The link below is with the sidepipes on and me standing next to the car. Not bad - only losing 12.8 hp between a correct length open exhaust and a much quieter sidepipe.
I will be putting together a new post after I compile my flywheel dyno data and baseline chassis dyno data - interesting comparison.
I've been in contact with Jere after seeing your exhaust. I had his old style road race headers on my 427 Corvette, but they exited way too low to drive the car on the street. I could just get my foot under the pipe where it came out from under the car.
Witz- how low are your headers? Can you post some pictures of how the tailpipes look where they exit the sidepipe covers? Thanks.
my local carquest carries them or you can try any medium duty truck supply store. they are great for clamping and removal later. for a complete seal use a little muffler cement around the area where the bols are and it will never leak.
I've had mine on and off several times with no problems or leaks. The trick is to use a lot of antisieze on the pipe. I think I have seen Ecklers selling them and at Summit Racing, too.
I finally had a few minutes to take a few photos showing the pipes under the covers. I decided to take Stahl's advice for maximum performance and not trim the tips to fit flush with the cover opening. This is the only only part that does not appear stock. Dyno testing next......
