Alternator help?
Old Sep 19, 2001 | 02:38 PM
ksems's Avatar
ksems
Default Alternator help?
Hi all,
Boy , seems like everything is bustin these days.
Here is the situation...
While driving the car all is normal ( for a C3 )
Then, the car is stumbling...I notice that the rpm is fine....the Voltage meter is not. If i increase the RPM, still doesnt help...
The voltage meter that was just reading around 14-15 volts is now reading 8 or 7.
Lights are dimming, radio dimming ,etc...
Then , as if touched by the Gods of Chevrolet, all goes back to normal.:rolleyes:
What gives, alternator?? :(
Kevin
[Modified by ksems, 12:39 PM 9/19/2001]
[Modified by ksems, 12:40 PM 9/19/2001]
Old Sep 19, 2001 | 03:03 PM
71coupe's Avatar
71coupe
Default Re: Alternator help? (ksems)
A quick way to check the alt - Start the motor & let it idle. Take a regular non-magnetic screwdriver and hold it to the back side of the alt.
If it's charging, it will generate an electro-magnetic field that will attract the screwdriver.
Have someone else watch the volt gauge while you do this to see what it's doing.
Old Sep 19, 2001 | 04:14 PM
john's '81 mouse's Avatar
john's '81 mouse
ksems:
Just went through something like you are experiencing with my '81. Finally discovered that the small white electrical lead which plugs into the alternator had some grease on it, and it would periodically loose connection and not charge properly. I removed alternator, disassembled, cleaned and regrease bearing area, and re-assembled and no more intermittent charging problems.
Your problem may be something different, like a bad connection or ground, but you just may have the same problem.
Old Sep 19, 2001 | 04:39 PM
TJKirby82CE's Avatar
TJKirby82CE
Take the alternator out and take it to a shop to be tested. yours is internally regulated so the
regulator can be going bad. Also clean ALL alternator connections and check battery cables
for acid or any sign of deterioration.Travis
Old Sep 19, 2001 | 05:39 PM
SteveG75's Avatar
SteveG75
Check connections.
If you look at the alternator, there is a two wire plug, usually brown and red. If the red wire breaks, the alternator field is not energized and the alternator will not charge. I have had this connector break twice (about every 3 years or so).
Old Sep 19, 2001 | 05:50 PM
GTR1999's Avatar
GTR1999
Default Re: Alternator help? (SteveG75)
I had the same thing happen on my 69, the plug was the original and very loose. I got a new plug splice kit from NAPA to solve the problem.
Gary
Old Sep 20, 2001 | 12:01 PM
ksems's Avatar
ksems
Thanks for the replies.
Ive got yet another weekend full of things :
- alternator
- replace rear u-joints
- check parking brake cable
- find source of mysterious rattle that goes away 30-45 seconds after I start the car ( heat riser valve ? )
well, the weather is supposed to be nice
Kevin
Old Sep 22, 2001 | 10:10 PM
ksems's Avatar
ksems
Hi all,
pulled the plug at the alternator and cleaned it quickly.
Reinstalled and drove ( running out of daylight )
It helped alot, I think that is the problem. The voltage did drop a little but noithing like before. I will take that connection off again and clean it thoroughly
tomorrow and I think this will solve it.
The half shaft u-joints took me most of the day.
Ill keep you all posted,
Kevin
Old Sep 22, 2001 | 10:48 PM
LAvetteman's Avatar
LAvetteman
St. Jude Contributor
I'd bring it to an alternator shop and have them go through it.
To Alternator help?
