Calculating DCR with a solid roller cam?
What intake valve closingtime (IVC) should I use when calculating the dynamic compression ratio (DCR) for my new engine?
The IVC on my solid roller cam is 72dgr after bdc at 0.015 lift on the tappet and 53dgr at 0.05.
On the KB-Silvolite calculator I'm using it is stated that I shall use the 0.05 IVC and ad another 15 deg but I have the feeling this is more relevant on a hydraulic cam compensating for the lifter flexing.
When I'm calculating my setup with 72dgr. I'll get 7.8 DCR which I find too low and doing the same with (53 + 15)dgr puts me in the better 8.2 DCR level.
What advice can you give me on the IVC so I can decide for the right cc on my heads? Thanks in advance.
What is your ci and .050 duration. I know enough to tell you what static you could run.
I'm not sure what you mean with ci but I have the following cam specs at 0.05: 9 deg open / 53 deg close total 242 and LCA 112 and 0.608 lift with 1.6 rockers.
My comp is 10.35:1 with my curent parts but I could have the heads milled for a higher ratio.
On the other hand I'm planing to run the engine on 95 octan Europe fuel which should be similar to 90 octan in the US and I want to keep away from knocking-problems.
Looking forward to hear you recomendations and best regards, dk-corvette.
My .050 cam is Intake BTDC 12 ABDC 46 Ex. BBDC 60.0 ATDC 6.0
238/246 LSA 112 installed 2 degrees retarded .635/.644 with 1.65 I rockers
What is your deck heighth? head combustion chamber cc's?
I'm getting away with 11.2:1 static with a total quench of .031 (0 decked with a .031 gasket) on 93 octane. I do have to retard the timing a few degrees in the summer to control the ping.
At .050 cam is Intake BTDC 9 ABDC 53 Ex. BBDC 53 ATDC 9, 242/242 LCA 112 grinded on a small base circle for stroker. It might be necessary to advance the timing 2 or 4 deg. we'll see on the dyno.
The block will be 0 decked. Probably end up somewhere between 0 and 0.005 and together with a 0.04 packing it gives a quench round 0.045.
bore and stroke is 4.03 x 4.0
I have a nice set of 68cc AFR heads that I planed to use for a 383. Then I decided to go for a 4" stroke instead but with 68cc this will put my comp to 11.1:1 which I'm afraid will be too high for the fuel. DCR 8.4 -8.7 depending on IVC but compared with Gkull's data this might work?
Therefore I'll think about selling them and get another set of heads in the 75cc size instead. Such will lower me to the mentioned 10.35:1 and a DCR 7.8 - 8.2.
What do you think about all of this?
The pistons are Mahle flat top 5cc. They have an incredible low weight of only 380g!!
The idea behind the cam was to make a real TQ-monster to match the 3.08 rear and the TH400 / 2400 stall the car has now. Inspired of the great results that Motorhead has with his cam setup we decided to use the same grinding from his inlet to both my inlet and exhaust.
With the fast acceleration cam grind together with the 1.6 rockers we hope to have something close to an "on/off" opening and closing of the valves ensuring an big opening area within a relative narrow (242) deg. The overlap was reduced by the 112LCA for reduced fuel consumption and driveability. It looks rather close to your cam but with the extra 25 cui of my engine it should go more in the TQ direction. I hope it will work.
I have a RPM airgap intake and a set of Hooker super comp 13/4" headers. Haven't decided for a carb yet. The engine builder suggests a Holley 750 DP but I am more in for a Mighty Demon 750-825 with ann. boosters. Any suggestion? Best regards.
My original 427 small block came equiped with a comp cams 242/248 110. It was really mild for that many CI. My compression has me limited to not to radical duration.
This is where picking the correct parts and compressin ratio is critical. You need to be in the 8-8.5 DCR range, any lower it's a lame duck, any higher and you have detonation problems. I am impressed that you are at least looking into this before bolting a motor together and wondering why it runs like crap with no power later. You need at least 11:1 CR to run a 240-250 deg cam, now you know why
That is exactly what I am afraid of too.
With the right inlet valve adjustment of 0.016 the valve will first be fully closed at 75-77deg ABDC. At this deg. the DCR will be in a much to low 7.6 level with 75cc heads but with my 68cc DCR will be perfect at 8.2.
Based on your great help I will therefore start out with the 68cc heads I already have. Thank you very much for your great advice.
