Air Filter Resto
Old Nov 7, 2006 | 02:32 PM
Chris Farrer's Avatar
Chris Farrer
Default Air Filter Resto
Help please! Just another one of those little jobs trying to put things back to original. When I bought my '72 BB the air cleaner had been played around with a bit. The flame arrestor and elbow off the base was missing. Since bought the items from Paragon but could someone answer three questions please:
How is the tube attached to the base originally, welded / rivetted ?
Is there a grommet which seals the arrestor to the tube on the base or is it just metal to metal.
Is the elbow for the BB the same as for the SB (I could only find a listing for the SB).
Any help would be appreciated please, no cars in Tasmania to compare it to.
Old Nov 14, 2006 | 05:55 PM
Chris Farrer
Default Air Cleaner Restoration
Can anyone help please
Old Nov 15, 2006 | 08:02 PM
72ls5fla's Avatar
72ls5fla
Chris,
I will look for you tomorrow.
I'm pretty sure the elbow is spot welded to the air cleaner.
The elbow - pretty sure - is different betwen BB and SB.
I will take a picture and post it for you.
Bill
Old Nov 15, 2006 | 08:31 PM
Chris Farrer
Default Air Filter Restoration
Hello Bill,
Thanks for your help. Also what color should the base be flat, semi gloss, enamel?
Chris
Old Nov 16, 2006 | 12:10 AM
bondoboy's Avatar
bondoboy
The breather tube is welded and the arrestor is pressed on. On my 71 350, I put on a weiand intake with a holley. I bought the open element air cleaner base for a big block and the factory hose that comes from the valve cover hooks up exactly to the breather tube.
Old Nov 16, 2006 | 12:38 PM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
this is my 68 327
Old Nov 16, 2006 | 06:58 PM
Chris Farrer
Thank you for the photos. The flame arrestor will work but the tube is a bit different. Think I can seen now what I need to do.
Best regards,
Chris
To Air Filter Resto
