Holley PCV Question
Old Nov 11, 2006 | 11:34 AM
spedaleden's Avatar
spedaleden
Default Holley PCV Question
Installed a Holley 750 with Vacuum Secondaries. My Question is how do you hook up the PCV. There is a small vacuum port on the front of the carb which is manifold vacuum but the port is so small.
I have set up the carb per Lars instructions and changed the vacuum secondaries spring to White. I changed the jets from 70 to 72.
Just wondering about PCV
Old Nov 11, 2006 | 11:47 AM
lars's Avatar
lars
There should be a 3/8" vacuum port in the rear of the carb throttle plate.
Old Nov 11, 2006 | 11:52 AM
spedaleden's Avatar
spedaleden
That is used for Power Brakes, can I Y tap it for both
Old Nov 11, 2006 | 12:30 PM
Fevre's Avatar
Fevre
I would not T your brake line with the PCV, see if the manifold has a vac port and hook the brakes to that and the PCV to the carb, you want all the vac you can get for the brakes with no chance of PCV valve failure causing problems
Old Nov 11, 2006 | 12:31 PM
evil herbavore's Avatar
evil herbavore
Most intakes also have a large vacuum port.
I connect the PCV to the carb's port and the PB to the runner the intake port is on so that all the PCV contents don't end up in just one cylinder.
Old Nov 11, 2006 | 01:16 PM
Gordonm's Avatar
Gordonm
The tap off the intake should be used for the brakes and the one on the carb should be used for the PCV valve.
Old Nov 11, 2006 | 03:05 PM
Thinpockets's Avatar
Thinpockets
My Holley has both an 1/8" and 3/8" inch ports on the very front of the carb. They are close together and slanted off to the drivers side. The 1/8" is connected to the vapor cannister and the 3/8" is connected to a tee on the PCV and it then continues to the other port on the vapor cannister.
Old Nov 11, 2006 | 04:20 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Agree with Evil above,..find a fitting that fits the intake and use that for your brakes. Then use the 3/8" port on the back of the carb (on the throttle plate) for the PCV.
Old Nov 11, 2006 | 10:24 PM
spedaleden's Avatar
spedaleden
In used the 3/8 fitting on the rear of the carb for brake booster. I used the small vacuum port on the front for PCV. I used thin vacuum line with an adapter to 3/8. Went for a ride and everything works fine. Set the floats, mixture and Idle.
I am using the port on the manifold for headlight vacuum. Car is has a 4 speed so only one port for vacuum. I guess I could of put a T-fitting in, buy it's working fine with the way I have it.
Motor is not running so, fuel pressure gauge reads low
To Holley PCV Question
