Lets talk about power shifting.
Old Nov 12, 2006 | 08:58 AM
jpatrick636's Avatar
jpatrick636
Originally Posted by norvalwilhelm
I don't think abusing someone elses car while they let you drive it is the right thing to do.
Lars would not do that. He certainly didn't do anything I wouldn't do and he didn't push anything to the limit. He just drove it like it was meant to be driven. I think some people are a little apprehensive about their Vettes and Lars gives them the experience of an expert driver.
Old Nov 12, 2006 | 09:01 AM
84rzv500r's Avatar
84rzv500r
Are you guys do in anything special to the engagement dogs?
On the bikes we undercut 7* the engagement dogs for positive gear engagement (up and down)
Old Nov 12, 2006 | 09:12 AM
Ironcross's Avatar
Ironcross
Originally Posted by MotorHead
I agree, and I might add, alot more fun in someone else's car
Not exactly in the someone elses car. Thats where the problems start. I was always approached to drive someone elses hot car or hot boat at the races. It seemed that unless a car or boat was proven some drivers/owners would get scared with a supercharger staring them in the face. I did what they couldn`t do and that was press on the gas. I did break a few of them and the parts were not cheap. If there was a weak link it would immediately show up. I felt bad when that happened, to walk away from a broken piece and go back to serious racing in mine. I finally gave up on those requests when a close friend doing a favor for another owner got killed in a blown flatbottom. You never know how safe someone elses piece actually can be. A good reason why they may have been afraid of it.
Old Nov 12, 2006 | 09:26 AM
84rzv500r's Avatar
84rzv500r
Good advice.
Old Nov 12, 2006 | 09:29 AM
jpatrick636
Your right. Lars never got to drive the nitro funny car I had back at the shop.
Old Nov 12, 2006 | 01:32 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Originally Posted by 7t2vette
Powersshifting: full throttle, shift at redline as fast as you can without lifting off the gas! Awesome experience, unless you are a girly man afraid of breaking your car!
Pretty easy to do in an automatic.
Put a $10,000 imotor n yours and back it up with a brand new $4,500 tranny, all in Canadian funds, and I'll sit in the passenger seat and watch you drive over your driveshaft and few other misc. parts
This means I am kidding, I used to power shift my '70 Cuda all the time, it seemed to be able to handle it, and on that note, I would never do it in someone else's car
Old Nov 12, 2006 | 01:47 PM
AlCherry's Avatar
AlCherry
Back cut gears, engine kill with air shifter, or engine kill with manual shifting. Though I use Pingels fairly new all electric shifting. (has up and down)
www.cherryfamilyracing.com
Old Nov 12, 2006 | 01:52 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
I've got a >$10,000 motor in my car (the short block alone cost me $7000; I went all forged), and as soon as I get the TKO-500 in and the TH400 out, I will be powershifting all day long! When I built my car, I didn't cheap out on anything, so I know it will be up to task for the abuse.
To each his own, I guess.
Old Nov 12, 2006 | 02:13 PM
MotorHead's Avatar
MotorHead
I'll be there watching
Old Nov 12, 2006 | 05:10 PM
panic's Avatar
panic
Originally Posted by oregonsharkman
Ok; I have heard 2 versions.
1) full throttle, shift at redline, blip the clutch/throttle and shift.
2) full throttle, shift at redline, NO clutch, just SLAM into next gear with full throttle still on!
#2 sounds like death to tranny (if it even works, I have never tried it myself)
if you really have enough power you can avoid the 2) shifting.
power makes the difference, i've always had to do what you describe in no 2 shifting when i had less power then my (track) enemies, when i had enough (which means 'more') they had to do it and i've always won shifting 'comfortably'
Old Nov 12, 2006 | 05:13 PM
panic's Avatar
panic
Originally Posted by BigBlockk
If you want to do number 2 you'll need one of these.
http://www.jericoperformance.com/11.html
BigBlockk
Later.....
would this fit streight into a '77 in the place of a t-10?
Old Nov 12, 2006 | 06:50 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Here's another option..
http://www.lencoracing.com/ST1200MasterPage.html
of if you want to go completely crazy...
http://www.lencoracing.com/CS1MasterPage.html
Old Nov 12, 2006 | 06:59 PM
  #33
7t2vette's Avatar
7t2vette
Better bring your CAA card for the tow, and the bucket and shovel for my broken and scattered driveline parts, just in case!!!
Real men power shift; girly men don't!
Old Nov 12, 2006 | 07:24 PM
  #34
Ironcross's Avatar
Ironcross
Lencos are for clutchless shifting, and a bunch of Ford C4 parts in each unit with a reverser on the end or back. I was the first one to use a Lenco 2 speed in a AA/Fuel Altered.
Old Nov 12, 2006 | 07:38 PM
  #35
63mako's Avatar
63mako
St. Jude Donor '08-'09
Originally Posted by 63mako
Wind it up to redline. With right foot on floor bang the clutch to the floor as you shift to the next gear and the clutch foot slides off the clutch to the left just as it hits the floor. The shift is almost instantanious. Your talking hundreths of a second. Yes I have torn out many muncie's in my day but also have won many races against much stronger cars. No guts, No glory! Don't miss the gear!
A rev limiter is a good idea with this type of shift.
Old Nov 12, 2006 | 11:16 PM
  #36
panchop's Avatar
panchop
Are you saying you can disengege your tranny under WFO without the clutch. I routinly blip the throttle on my bikes for clutchless shifts but havent been able to pull my TKO out of gear without using the clutch. Maybe i am just not yanking hard enough although I don't think I will be trying without cutting the gas.
Old Nov 13, 2006 | 11:24 AM
  #37
lars's Avatar
lars
I know a few guys that can really power shift well but they do blow a tranny yearly.
I've never abused anyone's car - not even close. I short-shift so conservatively when driving other's people's stuff that I could probably miss the shift and still not zip it past redline.
I don't see the fear of this power shifting or what the mystery is. I've been racing 4-speed cars on the track and street for 30 years. No rev limiters, no special trannys. I power shift my own cars at redline, and I run slicks at the track. I have never once blown an engine, tranny or rear end from power shifting with no throttle lift. I have, however, replaced the synchros in my M22 after 3 seasons of racing, and I go through a clutch every other season. Power shifting is no big deal, and it doesn't break cars... that's nonsense. But use the clutch...
To Lets talk about power shifting.
Old Nov 13, 2006 | 01:33 PM
  #38
mandm1200's Avatar
mandm1200
There is no real need to powershift around town. Racing is different and it will help. Best thing is to pratice at rpms lower than redline.
Is it harder on the drivetrain? Yes.
Will it break something? Normally not.
Is it scary the first time? Yes.
Does that feeling go away? Yes, for the most part.
Old Nov 13, 2006 | 02:12 PM
  #39
rexx78's Avatar
rexx78
Good post
I thought #1 was power shifting, and #2 was just shifting fast.
The shift in #2 takes a split second. I wonder what the difference is if you let off the gas for that split second?
I never tried #1 because it seemed like it would break something.
Old Nov 13, 2006 | 03:53 PM
  #40
7t2vette's Avatar
7t2vette
100%
I don't know why people are afraid of the power shift, it's not that big a deal. I've been doing it for years with no problems with my engines, trannys, or rear diffs. Now I'm not talking every shift being a power shift, but every once in a while isn't going to hurt a street car with radials on it. Funny story: back in '91, I bought a new 5.0 Mustang LX; during the test drive, I drove to an industrial area, told the salesman to hold on, and then did a WOT pass from a roll, power shifting the first three gears! The look on his face was priceless, that car laid rubber almost the entire time!!! I bought the car, and the next day when I picked it up, I power shifted off the lot too!!!
Girly men are afraid of breaking their cars!
