Holley Short Spring Question
Old Nov 17, 2006 | 03:34 PM
spedaleden's Avatar
spedaleden
Default Holley Short Spring Question
I have the Holley spring kit and Lars talks about a short white spring. The only spring in this kit is white, but I would not say it's short, it is about the same size as the others.
I take it this is the spring he is talking about.
If I am looking down the carb and i rev the motor, should I see the secondarys open?
Old Nov 17, 2006 | 05:11 PM
evil herbavore's Avatar
evil herbavore
I press one spring against another to find the weakest.
You WILL NOT see the vacuum secondaries open just winging it in the driveway.
Old Nov 18, 2006 | 08:40 AM
MN80Vette's Avatar
MN80Vette
Google "holley carb tuning" and you will learn that vacuum secondaries only work under load and are tested at WOT on a dyno.
What problem are you trying to fix? As your Holley carb instruction manual may explain, too light of a secondary spring can cause other problems.
Old Nov 18, 2006 | 08:44 AM
Fevre's Avatar
Fevre
Wish I had the quick change spring kit since changing it out is a pain
Here is a chart from my Holley tuning book, kinda hard to see from this scan so I can e-mail it if you like
BTW It only lists one white spring and 2 yellow, one of which is short.
Old Nov 20, 2006 | 11:52 AM
lars's Avatar
lars
There are 2 white springs in the kit - one tall (regular size) and one short. The short white is the softest spring and will give you the quickest secondary opening.
Old Nov 20, 2006 | 01:58 PM
spedaleden's Avatar
spedaleden
I bet I have the tall in there.
Old Nov 20, 2006 | 02:03 PM
lars's Avatar
lars
No - you can't get the secondaries to open by rev'ing in neutral. There is not anough airflow through the primary side under no-load condition.
To Holley Short Spring Question
