panel bonding
Old Nov 18, 2006 | 12:53 PM
edward lamb's Avatar
edward lamb
Default panel bonding
has any one every replaced the fiberglass door post panel ? I cut mine out in order to repair the bird cage I left the quarter pretty much in place. I have a nos to install but can't make a decesion on what to use to rebond it . Should I use something like duramix or Fursor or Vette bond II ? should this panel also be glued to the bird cage ? I actual bought the vette bond but was not sure if it would bond to the bird cage if that was neccessary Thanks ED.L
Old Nov 18, 2006 | 06:24 PM
paulywannafly's Avatar
paulywannafly
Hi
As the supplier of Vettebond II to Corvette central Now called fiber glue,
I can assure you that this product will bond fiberglass to steel as well as it bonds fiberglass to fiberglass . We have homie cars with the kits glued on and drag cars with bonded on hood scoops never heard of a part coming loose yet. Pm me if you would like further instructions
Thank you for your purchace Paul
