Winter projects, who's doing what?
Old Sep 23, 2001 | 01:06 AM
joeveto's Avatar
joeveto
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
Default Winter projects, who's doing what?
I'm looking to late fall, winter, and early spring, and I'm creating of list of jobs I want to do on the Vette. Here's my list. What are the rest of you doing?
1. Detail the rest of the frame.
2. Pull the motor and check the clearances, clean it up (I'm working on a new motor, this is a half step and dry run before the new one goes in).
3. Fix the clock.
4. New master cylinder.
5. New power steering pump.
6. Fix the cruise control (new transducer).
7. Eliminate the noise in the stereo.
8. Complete a general detail of the engine compartment.
For now, that's all I have. If time and inclination permit, I may yank the pumpkin and have it rebuilt. But I'm not sure about this one.
So let me have it. I want to hear what everyone else is doing.
:yesnod:
Old Sep 23, 2001 | 01:19 AM
slide's Avatar
slide
Default Re: Winter projects, who's doing what? (joeveto)
My list is to long to put on the forum so I'll just say I'm hoping to finish the restoration of my 75 that I started last winter. :flag
Slide
Old Sep 23, 2001 | 01:36 AM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Default Re: Winter projects, who's doing what? (slide)
700R4 and chopping the front springs down. I guess I will replace all the bushing will I'm at it.
Good Luck
Budman
Old Sep 23, 2001 | 03:39 AM
tunedport78's Avatar
tunedport78
Winter? Whats That?
Old Sep 23, 2001 | 05:32 AM
strat68's Avatar
strat68
Default Re: Winter projects, who's doing what? (tunedport78)
#1 paint
#2 new carpet
#3 new seat covers
If i get all of these things done by spring I will be soooooooo happy :D
joeveto good luck with your list :cheers:
Old Sep 23, 2001 | 10:16 AM
rrent's Avatar
rrent
I'm kinda with tunedport78 - it'll be a couple of months 'till we have anything that vaguely resembles "winter". I do have a few short term projects though:
buy and install new radiator
buy and install F41 front springs
find and figure out how to pay for new ('79-'82) seats
or
buy and figure out how to install new seat covers
and lastly taek the rear end for complete checkout
Old Sep 23, 2001 | 10:20 AM
PatsLs1vette's Avatar
PatsLs1vette
Default Re: Winter projects, who's doing what? (rrent)
my winter project started early it was supposed to be paint but after i got the rear done and the exuast and rear suspension i went right into sanding and disassembly,so i guess my winter started early :rolleyes:
Old Sep 23, 2001 | 11:42 AM
xfactor974's Avatar
xfactor974
Default Re: Winter projects, who's doing what? (pats406nitrovette)
I going to put that 700R4 in that's been sitting here. Then maybe I'll work on the EMI noise in my stero and then do a full poly suspension upgrade. :D :D
Old Sep 23, 2001 | 11:45 AM
A C's Avatar
A C
Cruise-In II Veteran
Well, our low for today is supposed to be 37 degrees, so I think winter is close. :sad: I am thinking that I can put in a pretty big cam if the lifters have rollers on em....hehe :cheers: . I should start a used cam store....I have a bunch of cams with only one summer on them. I actually got one that was TOO streetable last time....nobody looks over at the stoplights anymore because it doesn't lope :( .
AC
Old Sep 23, 2001 | 12:20 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: Winter projects, who's doing what? (A C)
1. Front suspension rebuild and detail.
2. Power steering installation.
3. Possibly pull the engine and go through it?
4. Fix the clock.
5. Put a radio in that gaping hole in the dash.
6. Whatever else seems like needs to be done at the time.
Old Sep 23, 2001 | 02:09 PM
SteveG75's Avatar
SteveG75
1. Pull motor. Rebuild. Maybe 383. Hydraulic roller maybe.
2. Get T-10 rebuilt (darn synchros) at same time. (Tremec swap on hold for $$$ reasons right now).
3. Detail engine compartment while out.
4. Get rear end checked to eliminate annoying clunk.
5. Eliminate annoying cold brake squeak.
6. Rear wheel bearing check, rebuild as necessary.
7. Smart struts/6-link maybe??
8. New stereo???
Oh my, I think I just ran out of $$$. :flag
Old Sep 23, 2001 | 02:59 PM
Captain Morgan's Avatar
Captain Morgan
Cruise-In III Veteran
Cruise-In V Veteran
Default Re: Winter projects, who's doing what? (SteveG75)
Steve, as far as your rear end clunk, have you checked the support bushings for the diff? I had a clunking problem on my 79 and it turned out that the lower bushing was almost completly gone. Take a look underneath and you will see a support that bolts to the diff and then to the frame in front of the diff. There should be a bushing there, about 2 inches round.
Anyway, here is my winter project, spend all of my money before I earn it, list:
1. Fairly easy - replace valve cover gaskets
2. Install headers and true dual exhaust
3. Install new suspension (front and rear), HD rear diff cover, new ball joints and tie rod ends.
I'll probably just replace the current bad ball joint this winter and then do the full replacement next winter. I seriously doubt I'll have the money to do it all this winter.
Old Sep 23, 2001 | 03:18 PM
WESCH's Avatar
WESCH
Hi SteveG75
You mentioned the 6 link smart struts.
There was post about this 6 link mod, but I think nobody knew the dealer for this kit.
Do you have a dealer address ?
My winter projects are :
replacing the struts due to both are bent.
installing aftermaket seats
manufacture a stainless roll bar, possibly with double loops following the headrests of the new seats.
might install power brake booster.
front and back poly bushings , if time permits.
possible reinstallation of wiper door assembly , has aftermarked long hood installed presently.
and lots more , as time and money permits.
By the way, my car is a 68 big block convertible with beautifull hooker side exhaust. This turns heads also without a hi-lift cam as you can hear the solid lifters in between the beautifull rumbling big block noise.
I love it.
Gunther :seeya
Old Sep 23, 2001 | 03:43 PM
nastee383's Avatar
nastee383
Engine/trans swap: 630hp/605tq 502cid BB, JET 480LE trans.
Old Sep 23, 2001 | 05:40 PM
454Big's Avatar
454Big
Progress with the suspension!!!
Lift Body, blast frame, powdercoat the thing.....
Bring it on the road before 2020....... :D
[Modified by 454Big, 3:44 PM 9/23/2001]
Old Sep 23, 2001 | 08:24 PM
LT1driver's Avatar
LT1driver
Default Re: Winter projects, who's doing what? (strat68)
Tunedport, I hear ya, winter.....nah. Actually I plan to work on my big block and get it into my other car. :D :blueangel: :flag
Old Sep 23, 2001 | 08:36 PM
daniel77350's Avatar
daniel77350
Default Re: Winter projects, who's doing what? (LT1driver)
my winter projects:
-Get it back from the paint booth(a project in itself)
-New weatherstripping
-new door pannels
-complete interior restoration
-clean up engine compartment
-new rear spring
rubber suspencion componants(I thought about going poly, but I heard horror stories about poly, so in 20 years I will just replace the rubber again, no biggie :rolleyes: )
-cruise with the t-tops on and the windows down(our winters are not THAT cold, maybe high mid 40's).
-install 268H cam, new lifters, springs
-install Comp headers from Hooker
Thats it for now...I will be broke after the first 4 on my list, but hopefully I will be able to do all of my list.
Daniel
To Winter projects, who's doing what?
Old Sep 23, 2001 | 08:38 PM
Anar76's Avatar
Anar76
Default Re: Winter projects, who's doing what? (daniel77350)
I wish I could make a list.
My plans change wayyyy too often.
But this winter I plan on restoring my `66 mustang.
Spring I plan to rebuild my vettes 350.
and ???
Old Sep 23, 2001 | 09:35 PM
tnt76vette's Avatar
tnt76vette
Default Re: Winter projects, who's doing what? (Anar76)
#1. Send my stock Q-Jet to Lars for a rebuild... :lol: #2. Install Lars advance kit that I,ve had all summer :lol: #3. New shocks :yesnod: #4. Maybe a set of headers and maybe a set of roller rockers :flag :seeya
Old Sep 23, 2001 | 10:00 PM
Chris@VetteFinders's Avatar
Chris@VetteFinders
Platinum Supporting Dealership
Default Re: Winter projects, who's doing what? (tnt76vette)
Drive!!! Been waiting for "winter" so I can drive it when its cool.
