Not Original Motor
Old Nov 20, 2006 | 12:13 PM
SoCalErv's Avatar
SoCalErv
Army
Default Not Original Motor
I purchased a 69 vette knowing the engine was not the 350/300 original motor. However a condition before I bought it was for the vendor to asssure me it was a vette engine. Through the help of forum members it is very evident the engine I have is a 1973 350 from a truck. Suffix code is TJC
Is this worth raising hell with the vendor or does it make a difference in the long run since I knew it was not the original motor.
Old Nov 20, 2006 | 12:19 PM
wfo76's Avatar
wfo76
I would think that the 20/30 series truck engines will have 4-bolt mains and the same basic hardware that the original 300hp would have had, so if that is the case it would be no big deal. Many hi-po builders seek out the truck blocks.
Old Nov 20, 2006 | 12:33 PM
71rdster's Avatar
71rdster
I have a 4bolt truck block in mine. The casting numbers for blocks usually span a variety of cars. There isn't much reason to scream for a Vette engine, unless it was alleged to be a HIPO with internal goodies like forged crank, pink rods, high compression heads, solid lifters etc. Most everything else is pretty run of the mill and easily interchanged. You would be surprised at how many pickups I have heard about with "Vette" motors.
Old Nov 20, 2006 | 12:55 PM
markdtn's Avatar
markdtn
I would say leave it alone, it's probably a decent block to build. You knew it wasn't original anyway.
Old Nov 20, 2006 | 03:00 PM
Dr.G's Avatar
Dr.G
If you were told that it is a Vette engine and it is not, unless you got a good deal, I would be Pi$$ed
Old Nov 20, 2006 | 03:06 PM
ajkogut's Avatar
ajkogut
I have a truck block in mine, as well. If its not original anyways, I'm not sure it really matters WHATS in it (truck, other vette block).
Just my opinion...plus now you don't have to worry about blowing up a numbers matching car
Old Nov 20, 2006 | 03:48 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Mine came out of a '73 truck too, now it's 547HP of tire shredding fun
Old Nov 20, 2006 | 08:46 PM
LittleJake's Avatar
LittleJake
I pulled my matching numbers block to rebuild and am in the process of dropping a 4 bolt main truck block into my vette. I wouldnt be mad at all as long as you were not expecting a matching numbers vette. A lot (maybe most, but not positive) of the vette engines were 2 bolt mains so the truck block I would say is better. (not to start the debate over 4 vs 2 bolt mains, I have heard both sides hahaha)
Old Nov 20, 2006 | 08:58 PM
Red70vette's Avatar
Red70vette
The problem is not with the engine it is with the vendor misrepresenting it as a Corvette engine. If this vendor sells Corvettes then he knew it was not a Corvette engine. He misrepresented it on purpose, if he didn't know what it was then he should say so. He figured you wanted a Corvette engine so he told you a lie. He just figured that you weren't smart enough to figure it out yourself.
I would be pissed and let him know it. Also let us all know who it is since that is very dishonest. I would demand compensation of some sort. If you let him get away with it he will just screw someone in the future.
Old Nov 20, 2006 | 09:06 PM
dgruenke's Avatar
dgruenke
Now that it is in your vette, it IS a vette engine.
Seriously, the suffix codes says that it is a 4 bolt. If this is true, it is probably 2 more bolts per main cap than the original small block had.
At this point, if you knew the engine wasn't original, I wouldn't worry about it. No one will know it was truck engine, but you.
If you are upset that the dealer told you it was a vette engine, you could always get the dealer to pony up some cash. Here in Illinois, that constitutes Consumer Fraud, and the dealer could end up paying some money if he knew his statement was false.
Old Nov 20, 2006 | 09:42 PM
Ironcross's Avatar
Ironcross
It`s not where it came from, it`s where it`s placed. 350`s are 350`s
Old Nov 20, 2006 | 10:16 PM
Z-man's Avatar
Z-man
I'd threaten him and try to get some money back for "misrepresentation". Then I'd just keep the engine since they are all about the same anyway. You could use the money for goodies to add some HP...
Old Nov 20, 2006 | 11:25 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Since it's not the original motor, even another Vette engine won't do much if anything for value.
If you ever get the shortblock rebuilt, the "TJC" will likely be removed from the decking.
Old Nov 21, 2006 | 12:11 AM
PRNDL's Avatar
PRNDL
It is annoying because he lied, and probably would have lied about anything to get you to buy it! But since you knew it was NOM, whether or not it is a "vette" engine is really not important, and you probably shouldn't have bothered making that a condition of purchase. Would you be happier if it was a blue flame 6 out of a 54? You should let him know that you know (he lied) but not much point in taking it farther than that.
Old Nov 21, 2006 | 03:16 AM
DZRick's Avatar
DZRick
Unless sometime down the road he were to decide to sell (said vette motor) to a vette owner to give this guy a correct motor.
I'd be pissed!
To Not Original Motor
