Timming Per Lars
Old Nov 22, 2006 | 05:38 PM
spedaleden's Avatar
spedaleden
Default Timming Per Lars
I hope I have it right. I shimmed the dist. per lars instructions. I place the two gold springs in the dist, (HEI) per lars. With vacuum connected to manifold because car idles better. At idle 16 degress and 2500 RPM 36 degrees.
Please tell me its right.
Old Nov 22, 2006 | 05:49 PM
lars's Avatar
lars
Perfect, assuming those numbers are with the vacuum disconnected.
Old Nov 22, 2006 | 05:50 PM
Scott Marzahl's Avatar
Scott Marzahl
I think you should be checking the timing with the vacuum disconnected, 36 degrees by 2,500-2,700 RPMs.
Old Nov 22, 2006 | 06:12 PM
spedaleden's Avatar
spedaleden
That is with vacuum disconnected.
Lars,
Thanks again for the patience and answering so many questions. I have leared alot and will pass your information along. I have the correct spring in the secondarys and the paper clip trick worked great.
Thanks again
To Timming Per Lars
