Alternator Pulley Removal
Old Nov 24, 2006 | 04:11 PM
DO2G's Avatar
DO2G
Default Alternator Pulley Removal
Are there any tricks to getting the alt pulley off? I can't break the nut free.
Old Nov 24, 2006 | 04:14 PM
onaqwst's Avatar
onaqwst
i'm in the same boat... i tried yesterday.......
b
Old Nov 24, 2006 | 04:30 PM
84rzv500r's Avatar
84rzv500r
Thinwall socket, a rag or leather gloves, a cold beer, and a 1/2 inch air impact.
The rag and gloves are optional...
Old Nov 24, 2006 | 04:38 PM
DO2G's Avatar
DO2G
How do you stop it from spinning? There is no way using a rag an gloves will hold it when using the air.
Old Nov 24, 2006 | 04:40 PM
Durango_Boy's Avatar
Durango_Boy
Actually, I have done this several times with NO gloves or rag. Just hold the pulley tight in your hand. Put the impact gun and socket on the nut, and pull the trigger. It may tug at your hand a little, but the nut should come right out. The glove or rag just helps if the nut is being a pain, and the pulley slips a lot. Give it a shot, and you'll be a believer. I wasn't until I finally tried it.
Old Nov 24, 2006 | 05:10 PM
redvetracr's Avatar
redvetracr
thats a left handed thread isn`t it??
...redvetracr
Old Nov 24, 2006 | 05:22 PM
Durango_Boy
...redvetracr
I just checked a spare alt I have in the garage. standard threading. Lefty Loosey, Righty Tighty.
Old Nov 24, 2006 | 06:07 PM
Highhat's Avatar
Highhat
Here's how I do it if you can visualize it --provided you cant break it free while it's still in the car.
Take the alternator out of the car.
Insert the allen wrench (the shorter end) into the middle nut.
Then, using a bench vise, put the other end of the allen wrench into the vise. You might have to turn the alternator sideways depending upon the height of your vise.
Then loosen the nut with a wrench. You may have to smack the wrench with a hammer.
Old Nov 24, 2006 | 06:09 PM
LYLE's Avatar
LYLE
Back off the air pressure to 80#s and hold the fan with a rag and gloves. A 1/2 air wrench should hammer it off. Turn pressure up if needed
Old Nov 25, 2006 | 05:46 AM
guppie's Avatar
guppie
St. Jude Donor '08
I always use the glove or rag, it's easier on the hand
Old Nov 25, 2006 | 06:23 AM
Joe45's Avatar
Joe45
Another method that protects the hands is to obtain a strap wrench. Similar to an oil filter wrench. I've used this several times. Strap locks on pulley to enable removing nut.
Old Nov 25, 2006 | 08:02 AM
DO2G's Avatar
DO2G
I will try the glove and rag method with air later today and post my results.
Since I have it all apart during the rebuild.....I glass beaded the housing it looks awesome. I will post pictures later.
Old Nov 25, 2006 | 08:03 AM
kb2fzq's Avatar
kb2fzq
Originally Posted by Highhat
....Insert the allen wrench (the shorter end) into the middle nut.....
This is how I got mine off, BUT...my problem was getting the half shell off the shaft...took it to a alt rebuild shop and they pressed it off in a second...I probably could have gotten it off myself eventually, Mr Impatient here...I wanted to pay him, he shook his head, smiled and said..."Have fun" (I mentioned it was off my 76 Corvette)
Old Nov 25, 2006 | 03:09 PM
Durango_Boy
Could you press the cases on and off easily with a press like can be bought at Harbor Freight? I have access to one of those, and a few alts I want to de-case.
Old Nov 25, 2006 | 04:02 PM
onaqwst's Avatar
onaqwst
i got mine off today..... i took a longer allen wrench (L) and used the a-arm to hold the pressure of the allen....then used an adjustable to loosen the bolt........ i would recommend some wd to help get the fan off...
b
Old Nov 25, 2006 | 08:35 PM
DO2G's Avatar
DO2G
Got it off using the air gun. The speed and torque of the gun broke the nut free. I didn't even need to hold the shaft. The most difficult part of the rebuild was pressing the new bearings in.
Old Nov 25, 2006 | 08:38 PM
Durango_Boy
Is this an original numbers matching case you're trying to keep? Are you rebuilding it with a higher voltage this time?
To Alternator Pulley Removal
Old Nov 26, 2006 | 02:35 AM
gofastvette's Avatar
gofastvette
All thats too it, a 2-3 second job! Put it back on by reversing the proceedure.
Old Nov 26, 2006 | 08:39 AM
DO2G's Avatar
DO2G
It's the original...I'm trying to keep it numbers matching as much as possible. I kept the amps and volts original. If I had to do it over again...I would have bought a rebuild and swapped the guts and gave the core back with my old parts and new housing.....oh well.
I bead blasted the housing and didn't realize there was a rear bearing, until it was back together becuase it didn't want to spin very easy, so now I have taken it all back apart to change the rear bearing.
After the bead blasting I used aluminum polish on the hosuing and it looks great.
Thank you everyone for the help.
Old Nov 26, 2006 | 08:44 AM
mailbox1024's Avatar
mailbox1024
Never had a problem removing one with a 1/2 inch drive impact. The short fast burst with the gun should be enough to break it free. If you dont have an impact gun, just take it to a local garage. Should have it off in 10 seconds or less and i doubt if they will charge you a fee for doing it. Offer a tip or box of donuts for the workers as a nice gesture. I done this for all my customers n/c while i still had my garage.
good luck.........
