door panel question
Old Nov 26, 2006 | 07:20 PM
caseybandy7777's Avatar
caseybandy7777
Default door panel question
I am reinstalling my interior door panels on my 79 and I am running into a problem. after I get the panels re-installed evrything looks good. then I shut the doors and the top pops off the lip at the top of the doors. Is there a trick to this?
Old Nov 26, 2006 | 07:29 PM
mr303's Avatar
mr303
Are they repo panels? I have some plastic backed repo ones on my car and they do the same thing! I think they just do not fit the doors like the originals.
Old Nov 26, 2006 | 07:32 PM
caseybandy7777
no they are the originals
Old Nov 26, 2006 | 07:45 PM
mr303's Avatar
mr303
Well I hope that somebody has some ideas! I was thinking of heating and bending mine to fit the door better, but this is not a option for you with the factory panels.
Old Nov 26, 2006 | 09:06 PM
SIXFOOTER's Avatar
SIXFOOTER
Did you have the door off? Sounds like the door is to far forward and its contacting the dash. Was the dash off?
Old Nov 26, 2006 | 09:44 PM
mr303's Avatar
mr303
Same here! Top of panel pops off lip of door frame, Its not hitting dash or other panels.
Old Nov 26, 2006 | 10:30 PM
SIXFOOTER's Avatar
SIXFOOTER
MIne has a screw on top near the rear edge of the door
Old Nov 26, 2006 | 10:35 PM
caseybandy7777
no I have already checked that. it appears that the action of the door closing jars the top off of the lip
Old Nov 27, 2006 | 08:15 AM
caseybandy7777
any ics of that screw at the top of your door mine dose not have a screw but I will put one in if it will solve the problem
Old Nov 27, 2006 | 09:13 AM
SIXFOOTER's Avatar
SIXFOOTER
Don't have any pics, I can get you one this evening tho. Its a chrome philips with an upholstry washer on it.
Old Nov 27, 2006 | 10:12 PM
caseybandy7777
that would be great
Old Nov 27, 2006 | 10:34 PM
ford4play's Avatar
ford4play
hope im not telling u what u already know here. when u get panel on, hook top first by holding panel away from door on 45 degree angle and hitting top of door panel, once locked at the top, everything should fall into place. im thinking ur getting panel on, but not getting top to hook in first. really hope this helps
Old Nov 28, 2006 | 06:42 AM
caseybandy7777
that is exactly what I am doing and after it is all put together it looks great. then I close the door and the top pops off. I realy think it is the jaring of the door that pops it loose
To door panel question
