Boost this....
Old Jan 31, 2007 | 11:50 AM
  #41
BB72's Avatar
BB72
Default Whats the CFDP
Originally Posted by big_G
I am a ProCharger dealer.......MSRP for my kit is $4,096.00.
That would be Corvette Forum Dealer Pricing.
Old Jan 31, 2007 | 12:02 PM
  #42
big_G's Avatar
big_G
I don't know what that means. I do know what MSRP (Manufacturers Suggested Retail Price ) means. This is a "suggested" selling price. AFAIK, Pro-Charger (ATI) does not allow retail sales of their kits, unlike Vortec. Technically, only the dealer can be the installer. I'm sure this is to help insure the units only get installed on engines built to handle the increased power.
Old Jan 31, 2007 | 01:52 PM
  #43
SHAKERATTLEROLL's Avatar
SHAKERATTLEROLL
I think it was meant as more of a ?. As in is this the price you would ask for the kit of the members of The Corvette Forum?
Old Jan 31, 2007 | 02:01 PM
  #44
big_G's Avatar
big_G
As a dealer, I belive I cannot sell to anyone, forum member or not. Only for "at my shop" installs. But I have seen units and kits for sale on-line. That said, I'm sure I could "work something out"...
Old Jan 31, 2007 | 06:44 PM
  #45
supervette2's Avatar
supervette2
Welcome to the Procharger club!!!!
Old Jan 31, 2007 | 06:45 PM
  #46
supervette2
what kind of numbers are you aiming for this beast???
Old Jan 31, 2007 | 06:47 PM
  #47
supervette2
BB72 does that include intercooler also? If so thats a steal but if not.....
Old Jan 31, 2007 | 10:35 PM
  #48
big_G's Avatar
big_G
750 fwhp should be easy, maybe a little more. Torque should be around 650 at the crank
Old Jan 31, 2007 | 10:45 PM
  #49
big_G's Avatar
big_G
That price includes the intercooler.
Old Mar 23, 2007 | 02:49 PM
  #50
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
Not if it takes 4 months to install. You still friggin with this?
Old Mar 23, 2007 | 06:20 PM
  #51
fugawi's Avatar
fugawi
bigG, you SUCK!!!!!!
Old Mar 23, 2007 | 09:34 PM
  #52
big_G's Avatar
big_G
Ty
Old Mar 23, 2007 | 09:36 PM
  #53
big_G's Avatar
big_G
I have a life, and am doing my install at my house as my time allows. I only got the block back a few weeks ago, then got the Flu..bla bla bla. It will be done soon, for you to envy.
Old Mar 23, 2007 | 10:46 PM
  #54
duno_much's Avatar
duno_much
1st Gear
dude i would have went with a c6 motor and topped it off with a kenne bell or whipple those things kick ***.............but you will still be kicking *** with the pro-charger im sure
Old Mar 25, 2007 | 09:49 AM
  #55
GUSTO14's Avatar
GUSTO14
big_G, you must be a transplanted Texan... real Texans don't get the flu!!! Something about the "jeans"...
GUSTO
Old Mar 25, 2007 | 11:05 AM
  #56
roscobbc's Avatar
roscobbc
I will relocate it to the passenger side. Also just received this morning my V/B tubular upper A-arms which are necessary in order to lower the blower sufficiently so the hood will close. Right now the blower is resting on the stock A-arms. Details, details.
At last. I have been waiting for someone to do exactly this. Some time ago I did provisional calculations to see whether a Vortech unit would fit under hood of my L36 427. Conclusion was that it would just about fit in the same position as yours. I was originally unsure if it was mounted as close as possible to underside of the hood/fender (not wanting a custom hood) if the upper A arm would run the risk of hitting the underside of the blower casing when suspension was on maximum deflection. I shall be replacing front springs soon and will take this opportunity to 'mock-up' the A arm without the spring and take measurements etc. Your answer of using tubular A arms is interesting, are you saying that this is the only way?. Does the blower now sit lower in between the A arm tubes?. How will you route cool air to inter/charge cooler and then to carb? and do you envisage the effect of all this on underhood temperatures? I am really interested in your findings here.
Old Mar 25, 2007 | 08:11 PM
  #57
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
That stinks because I can put together a high $ engine and have a Bridgeport mill sitting in my garage, but I have to buy a used ATI Procharger if I want one on my car because they don't feel I'm qualified to install their product onto my car even though I have the means to make what I'll need
Where I work, we make the gears that go into the ATI Prochargers
To Boost this....
Old Mar 25, 2007 | 09:58 PM
  #58
big_G's Avatar
big_G
I am trying to do this as clean as possible. I am about done with the intercooler plumbing...maybe a few more hours. The only other C-3 I have seen they tilted the radiator towards the engine about 4 inches so the intercooler pipes that go over the radiator support have clearance. My tilt-nose creates a lot of extra work, as the tilt supports intersect with the intercooler pluming. Another work-around..LOL. Hood clearance with a carb. will be a big issue if using a stock hood. Maybe an L-88 would work out. The tubular A-arms were a must, as it is now the lower blower bracket is resting on the alignment shims. Should not affect under-hood temps. ,just a little reduction in radiator airflow, as the intercooler covers about 40% of it. Pics in a few days, after I weld up the intercooler pipes.
Old Mar 26, 2007 | 07:00 AM
  #59
Russ57's Avatar
Russ57
Default Hope it clears
I tried a Procharger P600b on my 427 was going to do same mount on drivers side and put alt on pass.didn't think of tubular A-arms.Maybe wouldv'e fit with them except i don't think it wouldv'e had enough clearance if iI'd gotten on it to hard and got off quick do to motor mounts.....I gave up went to 174B&M not enough boost....going to 8-71....procharger going back on my 77 T/A....go luck hope it all fits!!!
Old Apr 7, 2007 | 11:45 PM
  #60
big_G's Avatar
big_G
Default Finally got blown tonight (get your mind out of the gutter)
Fired her up at 10 pm tonight, takes some of the pain of sending Uncle Sam several G's next week... Ran it in the garage without the carb. hat to purge the intercooler plumbing of debris and I was impressed at how much air the ProCharger put out at idle. Revved it up and the volume of discharged air was incredible! Now to modify the tilt nose pivots to clear the intercooler plumbing. I can't wait to get her on the road.
