Boost this....
Old Apr 8, 2007 | 04:29 AM
  #61
68 NJConv 454's Avatar
68 NJConv 454
Originally Posted by big_G
Very nice
Looks like the intercooler covers more than 40% of the radiator.
Keep an eye on the engine temp, maybe upgrade to a Mark VIII fan to pull extra air.
Old Apr 8, 2007 | 08:50 AM
  #62
DR.Jay's Avatar
DR.Jay
Fired her up at 10 pm tonight, takes some of the pain of sending Uncle Sam several G's next week... Ran it in the garage without the carb. hat to purge the intercooler plumbing of debris and I was impressed at how much air the ProCharger put out at idle. Revved it up and the volume of discharged air was incredible! Now to modify the tilt nose pivots to clear the intercooler plumbing. I can't wait to get her on the road.
It's coming along nicely. I can't wait to see it in action.
Job well done.
I've heard in the past there only two things in life that are diffinite "Death, and Taxes"
Old Apr 8, 2007 | 10:05 AM
  #63
shafrs3's Avatar
shafrs3
That dog 'ill hunt! (translation: Looks good)
You'll have to change you signature to "Honey, I don't know why the driveway turned black."
Old Apr 8, 2007 | 12:44 PM
  #64
big_G's Avatar
big_G
Job well done.
Thanks, Jason....
Originally Posted by 68 NJConv 454
Very nice
Thanks, it was a packaging challenge. There is a gap between the intercooler and radiator, and I run a very good electric fan. We will see.
Old Apr 8, 2007 | 02:51 PM
  #65
Monty's Avatar
Monty
You should be fine if you have good electric fans. The intercooler on my 1200hp TT SBC427 totally covered the radiator and a Spal dual electic fan setup kept it cool in any traffic/weather condition.
Very nice looking setup by the way!
Old Apr 8, 2007 | 03:50 PM
  #66
big_G's Avatar
big_G
Thanks, Monty.
Just got back from a few shake-down blips of the throttle to check things out. 5 pounds of boost at 3,000 rpm's, and 10 lbs at about 5,000. It is set up (geared) to max out at 16 lbs. around 6,500. From a 40 mph roll-out, absolutely no traction (2nd. gear) on the 295's above 4,000 rpm's. ......
Gonna be a learning curve for sure, and an interesting summer.
Old Apr 8, 2007 | 03:59 PM
  #67
Monty's Avatar
Monty
Good times, enjoy. Be safe and be careful. There's few things that'll give you that "white knuckle" feeling like punching the throttle at 70 mph and doing a burnout.
Old Apr 8, 2007 | 04:08 PM
  #68
big_G's Avatar
big_G
Yes, safety first. I am working with a fabricator on converting my 4 point cage to at least a 6 point with swing-out door bars, or whatever NHRA dictates. Dyno scheduling next to work out A/F ratios and timing.
Old Apr 8, 2007 | 08:26 PM
  #69
vetteaddic's Avatar
vetteaddic
Nice install What did you do on fuel system,sump on tank,1/2 fuel line?
Old Apr 8, 2007 | 08:44 PM
  #70
big_G's Avatar
big_G
Thanks...
Yes to the fuel lines...1/2 inch supply line, 3/8th return. No sump, just put a #10 bung close to the rear of the tank, then into an Aeromotive filter and pump. I am tired of the electric pump whine, which only got louder with the addition of the return line. Now I have a "Race pumps" pump and regulator ready to go in.
Old Apr 9, 2007 | 06:01 AM
  #71
jerome1979's Avatar
jerome1979
Great job big_G
Old Aug 1, 2007 | 06:00 AM
  #72
jerome1979's Avatar
jerome1979
Any update? video?
Big_G your set up is
Old Aug 1, 2007 | 08:13 AM
  #73
shafrs3's Avatar
shafrs3
Did you get your overheating problem resolved?
Old Aug 1, 2007 | 08:53 AM
  #74
big_G's Avatar
big_G
No video...no dyno...been raining so much here lately. Since I put a DeWitts radiator in, it is running a little cooler, but I still need a bigger electric fan. I really need to find a way to use vacuum advance on my application, if only for light throttle. That will help with cooling also.
Old Aug 1, 2007 | 09:40 AM
  #75
jerome1979's Avatar
jerome1979
have you try different spak plug? have you a MSD ignition with boost retard? use a Mark VII fan?
you probably ever try this but i want to help
PS: for rain use an hair dryer
Old Aug 1, 2007 | 09:51 AM
  #76
big_G's Avatar
big_G
I don't have any symptoms that would indicate the need for boost retard or different heat-range plugs. Only running 8.3:1 scr with a big cam, so I think I'm safe from detonation. Yes, a bigger fan is in the works. I am using a long water-pump and a spreader bar, so that limits my fan selection somewhat. cheers:
Old Aug 1, 2007 | 10:00 AM
  #77
jerome1979's Avatar
jerome1979
my idea is you set your timing at low rmp a litle bit high, so it help engine to be cooler when cruise, and when you are under boost your Boost controller limit advance to prevent detonation!? it's just an idea to help
To Boost this....
Old Aug 1, 2007 | 12:38 PM
  #78
big_G's Avatar
big_G
Interesting way to control timing.....but another expensive box I don't want to buy...lol
Old Aug 1, 2007 | 01:29 PM
  #79
norvalwilhelm's Avatar
norvalwilhelm
I felt the boost retart was necessary. Your 8.3 compression ratio turns into 15-1 under your 16 pound boost limitation. The boost retart can dial in 1 or 2 degrees of spark retart for every pound of boost.
It is a very nice looking setup
Old Oct 15, 2007 | 08:28 AM
  #80
jerome1979's Avatar
jerome1979
Any news?!
