distributor/timing problem - need solution
Old Dec 1, 2006 | 01:51 PM
greyghost79's Avatar
greyghost79
Default distributor/timing problem - need solution
o.k. 79 L82. modified by previous owner with aluminum L98 heads and headers with true dual exhaust. i've added digital ignition. other wise, engine stock as far as i know. has always been sluggish on bottom end. starts and runs "o.k." although seems to require excessive warm up time to idle cold (will die on cold start up in idle unless choke in and running on high idle cam for several minutes, even in hot weather). once warm runs o.k. and cruises well.
after reading some posts here decided to check TDC position of rotor. I put timing mark dead on TDC mark on balancer, pulled the distributor cap and to my surprise found the rotor pointing about halfway between #1 and #8 terminal?!?!?! WTF!!!!
How do I determine the exact problem here? without chasing my tail. how do I determine if the time marks have slipped, if the distributor is off a gear or if timing chain has jumped a gear?
like i said, it starts o.k. but has the above mentioned performance problems. i run 16 degrees intial advance with 36 all in by 2500 now. BUT apparently that's not what i've really got, is it?
what should i do to fix this? thanks for any input.
Old Dec 1, 2006 | 02:56 PM
marshrat99's Avatar
marshrat99
To determine if your balancer outer ring has slipped you'll need to determine TDC exactly.
1) pull all plugs and insert a piston stop in #1.
2) Gently rotate engine by hand until the #1 piston just touchs the stop. Make a thin mark on balancer directly across from the 0* mark on the timing tab.
3) Gently rotate the engine in the opposite direction until the piston again just touchs the stop. Make another thin mark on the balancer.
4) Make a 3rd mark on the balancer exactly 1/2 the distance between the 1st two marks. This is your true TDC.
Old Dec 1, 2006 | 03:32 PM
lars's Avatar
lars
Sounds normal to me. At TDC, the rotor should be past the #1 terminal and on its way to number 8. Keep in mind that the ignition fires anywhere from 10 to 54 degrees in advance of TDC - it does not fire at TDC. I think your setup sounds normal and correct.
Old Dec 1, 2006 | 03:36 PM
SIXFOOTER's Avatar
SIXFOOTER
Old Dec 1, 2006 | 03:42 PM
...Roger...'s Avatar
...Roger...
This is the way to be sure.
I also agree with Lars -it is a normal position for the rotor to be in.
Also performance timing is just shy of pinging-does it ping? If you bump it up a few degrees does it ping if so your in good shape.
Old Dec 1, 2006 | 08:13 PM
greyghost79
so, the initial timing i have is resulting in the rotor being past #1 terminal at TDC, correct? if I set initial timing to 0 degrees then the rotor should point directly at #1, is that right?
Old Dec 1, 2006 | 08:45 PM
...Roger...
Yes
Old Dec 1, 2006 | 09:26 PM
79vetter's Avatar
79vetter
So what is better for performance- set total timing to a certain pre-determined number like 36 degrees --- Or set timing with your ears (ping minus 2 degrees - wherever this may fall in total timing degrees) ?
Old Dec 1, 2006 | 11:05 PM
...Roger...
They are sorta the same.The safe way is 36 but when you do set your total timing to 36 you wouldnt leave it at 36 if it pinged.So 36 is not carved in stone.In my own cars I use the ping method for performance but I can monitor it and change it if needed.In customer cars for performance 36 is max. but that comes with a warning to use premium and listen for pinging.
To distributor/timing problem - need solution
