Hurst T-Handle question
Old Dec 6, 2006 | 05:09 PM
68350hp's Avatar
68350hp
Default Hurst T-Handle question
I'm lookin to get a Hurst T-Handle shift ***. Does anyone know what size thread I need for it to fix on my stock shifter?
Old Dec 6, 2006 | 05:31 PM
omng392's Avatar
omng392
Do you want to go back to the original? If so, check out ecklers. I believe the bottom nut to that mounts the shifter to the trans is a half inch...
Old Dec 6, 2006 | 05:46 PM
68350hp's Avatar
68350hp
No, I have the stock shifter from the factory with the lift up reverse lock out. I want to put a Hurst t-handle on my shifter. What i need to know is what size thread do i need to put on my shifter
Old Dec 6, 2006 | 05:58 PM
MN80Vette's Avatar
MN80Vette
I have a Hurst T-handle on my '80. I have the round white Hurst ball that came with the shifter at work. I can check the thread tomorrow and get back to you if you don't already have the answer by then.
Old Dec 6, 2006 | 06:03 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
The handle should come with a set of thread adapters. I just measured my stock shifter on my '78. It measured .545" dia - 18. I'm guessing that it works out to a 9/16-18 thread but it's closer to a 35/64th so I don't know what threads are offered.
Old Dec 6, 2006 | 06:30 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Yes get the Universal Fit 153-0019 brushed finish or chrome 153-0032 with the different thread adapters and use the one that fits your shifter lever.
To Hurst T-Handle question
