head lights problem
Old Dec 9, 2006 | 11:08 PM
oh6driver's Avatar
oh6driver
Default head lights problem
hey need some help. head lights on my 77 come up verrrry slowly and not together. right one came up first then left one came up. right one went down but left one now stays up. is it vacume or hinge problems. any help would be nice.
thanks scott
Old Dec 9, 2006 | 11:22 PM
...Roger...'s Avatar
...Roger...
Left actuator probably has a leak.
Old Dec 9, 2006 | 11:32 PM
martinsw's Avatar
martinsw
Probably an acutator vacuum leak. You can get seal kits from various vendors for ~ $15, remove acutator and replace seal & boot. I have done this a couple of times - a lot less expensive than replacing actuator.
Old Dec 10, 2006 | 09:03 AM
...Roger...
The seal only works on the extension side of the actuator.If there is a leak on "retraction" then the diaphram is bad and you have to replace it.
Old Dec 10, 2006 | 11:54 AM
Artsvette73's Avatar
Artsvette73
Just went through this on my 77. All the linkage and side door bearings were very stiff. Took everything apart, cleaned and put new grease on the linkage and bearings. Now they are ok for another 30 yrs.
Old Dec 10, 2006 | 09:53 PM
ford4play's Avatar
ford4play
just went thru this myself, checked everything out and found a few problems, but the big one was the vacuum relays. checked both actuators, and checked fine on vacuum pump, but the relay failed. they worked, but no longer hold vacuum
Old Dec 11, 2006 | 12:41 PM
saudivette's Avatar
saudivette
with vacuum IMHO
www.mcspeed.com
No more vacuum problems, ever!
Old Dec 11, 2006 | 12:44 PM
Durango_Boy's Avatar
Durango_Boy
Originally Posted by saudivette
with vacuum IMHO
www.mcspeed.com
Man you hate vacuum. Hydraulic power brake booster, electric headlight assemblies...what's next? A new non-vacuum distributor?
Make sure you tell me how the install goes for those electric lights. I have my own flush mount plan, but if that fails or falls through I'll be going electric too.
Old Dec 11, 2006 | 01:12 PM
saudivette's Avatar
saudivette
I just can't fathom the thinking behind the original vacuum headlights 100 lbs of relays, actuators, reservoirs and check valves and what must be close to 200 feet of rubber hose all to do the job of 2 electric motors
I scoured the forum for what to check/how to fix when my headlights didn't work properly and it seemed that I would find the problem, fix it, the headlights would be marginally better for a while then die again and something ELSE would need to be replaced
I've already installed the motors and they work great. I had a bit of grief with the right side headlight not coming up every time but that ended being the door binding. Fixed that and now my headlights rocket up and down every single time
It's a really simple mod Matt and you could easily do it in a day. Unless you want NCRS accuracy or you just love being under the hood chasing vacuum leaks, Mcspeed's mod is the way to go, IMHO.
When you get right down to it, vacuum sucks!
Old Dec 11, 2006 | 01:15 PM
Durango_Boy
Thanks for the tips. I know they are my backup plan. I'm working on a flush mount system similar to the L88 style, only the covers will be molded to house a pair of 4" bulbs. Should look pretty good if I ever can get to doing the glass work.
Old Dec 11, 2006 | 01:32 PM
saudivette's Avatar
saudivette
I prefer the standard look myself, but just didn't like the "you sure got a perty mouth" way they got them to operate
Old Dec 11, 2006 | 06:45 PM
MN80Vette's Avatar
MN80Vette
www.mcspeed.com
I've had electric Killer Lights and NO vacuum anything up front on my '80 for 3 years. I'm glad I didn't replace all the vacuum parts. I saved money and ended up with a better system.
Old Dec 11, 2006 | 08:51 PM
Durango_Boy
So in a situation where you have hydraulic assisted brakes and electric pop-up headlights...you won't need the accumulator for sure. Just the dist, PCV, and maybe the heater core valve needs vacuum huh?
Old Dec 11, 2006 | 09:00 PM
...Roger...
Did you install yourself ? How much time did it take for the install? How much did it cost?
Old Dec 12, 2006 | 01:20 AM
saudivette's Avatar
saudivette
I got all my parts reasonably cheap. If you buy everything new from GMpartsdirect, I think it will set you back $500 - $600. I got the C4 headlight switch from Ecklers, the C4 headlight module (with harness ends and plugs that I re-used) from eBay, the 2 x Firebird headlight motors from eBay, the headlight motor pigtails from GMpartsdirect and various coloured wire and inline fuses locally. I think I got away with it for around $300, including buying the bracket kit from Chris.
I installed everything myself. I spent a few hours making the harness (double checking it was all correct, then wrapping it like a factory item) and several hours over both days of a weekend to install it all. You could do it all in a full day...
Old Dec 12, 2006 | 09:30 AM
Durango_Boy
Hey Wayne I sent you a PM for part numbers and such. Thanks so much.
To head lights problem
