do i need to pull the engine out?
Old Dec 14, 2006 | 12:46 AM
panic's Avatar
panic
Default do i need to pull the engine out?
hi, do i need to pull the engine out to change flywheel? thanks/Giu
Old Dec 14, 2006 | 01:14 AM
SHAKERATTLEROLL's Avatar
SHAKERATTLEROLL
No you do not need to pull the motor.
Old Dec 14, 2006 | 01:15 AM
panic's Avatar
panic
trans maybe?
Old Dec 14, 2006 | 01:21 AM
SHAKERATTLEROLL
lol you are killing me here lol. But if you are not kidding then yes you have to pull the drive shaft,unhook the shifter and pull the trans,Then you would have to pull the bellhousing and then the pressure plate and clutch. Then you would be looking at the flywheel. You would remove the flywheel bolts and when you do replace the flywheel I would sugest that you purchase new flywheel bolts.
Old Dec 14, 2006 | 02:17 AM
panic's Avatar
panic
thanks skatter
Old Dec 14, 2006 | 02:20 AM
SHAKERATTLEROLL
You are very welcome Picnic. lol.
Old Dec 14, 2006 | 04:02 AM
jotto's Avatar
jotto
LMAO...
Old Dec 14, 2006 | 04:06 AM
panic's Avatar
panic
....... Picnic. lol.
Old Dec 14, 2006 | 04:09 AM
jotto's Avatar
jotto
Originally Posted by panic
thanks skatter
Old Dec 14, 2006 | 04:10 AM
jotto's Avatar
jotto
sorry...JK...couldnt resist!!!
Old Dec 14, 2006 | 04:43 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Skatter....shaker, it's all good.
Old Dec 14, 2006 | 05:20 AM
Bangkok Dean's Avatar
Bangkok Dean
Old Dec 14, 2006 | 05:42 AM
panic's Avatar
panic
Originally Posted by Bangkok Dean
Old Dec 14, 2006 | 06:29 AM
Graemeinvette's Avatar
Graemeinvette
When you go as far as heaving the box out, you might want to replace the the clutch & pressure plate as well.
Old Dec 14, 2006 | 07:08 AM
ghoastrider1's Avatar
ghoastrider1
you may also want to replace the little brass bushing, located in the center of the flywheel.
Old Dec 14, 2006 | 07:46 AM
norvalwilhelm's Avatar
norvalwilhelm
Can you pull the tranny with a fixed crossmember? If you can not now would be a good time to make that crossmember removable. Cut it if necessary and make life easier now and in the future.
Old Dec 14, 2006 | 07:56 AM
...Roger...'s Avatar
...Roger...
Sure you can. Panic-didnt you just replace the tranny?
To do i need to pull the engine out?
Old Dec 14, 2006 | 08:22 AM
Graemeinvette
This is turning into one of those 'and while you are doing that' threads.
Graeme
Old Dec 14, 2006 | 08:50 AM
BB72's Avatar
BB72
Default Hey
Your tunnel is dirty so you might as well detail that, now that the drive shaft is out the u-joints need......
Old Dec 14, 2006 | 09:15 AM
panic's Avatar
panic
Graeme
