powder forged rods
Old Dec 17, 2006 | 01:04 AM
Little Mouse's Avatar
Little Mouse
Default powder forged rods
Howards has 6.00 long 585 gram powder forged rods that they
are claiming high Hp rating on, anyone tried these rods.
Old Dec 17, 2006 | 07:04 PM
norvalwilhelm's Avatar
norvalwilhelm
Ford uses powder metalurgy for some of their rods and they actually break the cap off and then bolt the two broken surfaces back together.
I just don't like the idea of taking metal powder, filling a mold and then under pressure and heat cooking it into a forging.
It might be strong, I don't know but the idea scares me.
Old Dec 17, 2006 | 07:08 PM
Twin_Turbo's Avatar
Twin_Turbo
LT1 and up uses powder machined rods, they are actually pretty nice. Easy to match from factory (you basically put the desired amount / grams of pwoder into the mold and forge the rod), they are said to be stronger than pink rods but don't drop them, they easily crack that way.
Old Dec 17, 2006 | 07:53 PM
68/70Vette's Avatar
68/70Vette
I don't know very much about metallurgy; maybe enough to form erronious notions. I would think that the absolute most strongest rod would be a rod that was essentially a giant homogeneous perfect crystal. I would think that a powder rod, with the powder particles creating many small boundary layers, would not be the absolute strongest. If fact, I would think, notionally, that a powder rod would be succeptible to fracturing. What are the reasons that someone would make powder based rods anyhow? Maybe the powder based rods absorb piston shocks (compression) a little better than other techologies. But notionally, for the pull away forces, doesn't seem like they'd be that strong.
Old Dec 17, 2006 | 08:01 PM
norvalwilhelm
To me it is like grains of sand glued together. You can make consistent rods in both shape and weight with no wasted material but there are many grain boundaries.
Ford seems to be able to fracture the parting line between the rod and cap with accuracy and they then stick the fractured surfaces back together with bolts.
I too like the idea of taking a big chunk of hot steel and punch a rod out with a large press and mold. You get consistent flow lines of material
Old Dec 17, 2006 | 08:10 PM
Little Mouse
howards is bragging them up pretty good with the arp 2000
215psi bolts 650 hp with a set of 245psi bolts 850hp these are
probably a few seconds at a time drag racing ratings. I have a
set of eagle H beam rods rated at 700 hp but they are heavy.
Old Dec 17, 2006 | 08:57 PM
Solid LT1's Avatar
Solid LT1
We have observed Powder Metal rods from late LT1/LT4/HD truck motors with cracks on the cap. Better than Pink Rods my BEHIND! Heck! I wont even put Pink Rods back into a LT-1 or 302 Z/28 motor, those blocks are too hard to find today. Go with Crower Sportsman or Manley Sportmaster rods STAY AWAY FROM Hi-Tech!
Old Dec 17, 2006 | 11:30 PM
Little Mouse
I have been looking at crower and manley for awhile wanting a lighter
but strong rod, they both have the answer its just a matter of
opening the wallet up wide enough and selling off the eagle rods.
Old Dec 18, 2006 | 07:05 AM
Twin_Turbo's Avatar
Twin_Turbo
It's not like sand held together, well it's at first when they make the preliminary shape, a green compact that is sintered into a briquette. This is then hot forged to the final shape. And last it goes through a time/heat controlled cycle in a sinter oven. You know how sintering works right, where all the grains melt together, the amount of fusing can be controlled in the sinter oven w/ the heat/time control. This also removes most of the crystalline structure faults.
Splitting the cap by cracking is major reason why a lot of oem rods are now powder machined since it saves on expensive machining time and the cracked parts fit perfectly together, and the rough mating part positivly alignes the 2 pieces..
The wrought iron forging industry has since developed a crackable forged carbon steel to regain some of the market taken by the PM industry
an interesting read:
http://www.metal-powder.net/business...ess_jun05.html
Old Dec 18, 2006 | 09:19 AM
7T1vette's Avatar
7T1vette
Powdered metal (PM) technology has come a long way. As initially formed, PM parts are about 99% the density of poured steel; then they get hot forged (or cold forged) and increase in strength considerably. The advantage of PM is that they will not have the internal flaws that poured parts can have. That is usually what causes rod failures...not overstressing (unless you've selected the wrong parts).
Old Dec 18, 2006 | 10:14 AM
jackson's Avatar
jackson
Not all PM rods use fractured caps.
Those that do require different methodology to RE-size big end ... requires rod bearing with larger OD. Many shops won't mess with fractured cap rods.
Old Dec 18, 2006 | 10:15 AM
stingr69's Avatar
stingr69
Hard to argue with an inexpensive part that works as intended.
-Mark.
Old Dec 18, 2006 | 11:08 AM
Tom454's Avatar
Tom454
I particularly liked the last paragraph...
"To sum up, it appears that the AISI's case against powder-forged connecting rods is in tatters. It seems unfortunate that the Bar and Rod Market Development Group chose the approach of an academic study to promote the use of drop-forged steel con-rods. Arguments based on assumptions that might be passable in academic circles do not always hold up in the real world of commercial manufacturing. In the present case it seems the AISI has gone public with a conclusion that is essentially devoid of substance."
I find this all the time in "Materials Science" where I now work.
Re-sizing would be an issue for me. The cost could turn them into a "throw-away" part. Don't like that concept.
Old Dec 18, 2006 | 12:37 PM
Glensgages's Avatar
Glensgages
Solid LT1 :
your Private Message box is full
To powder forged rods
